Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Explorer Audio & Navigation
Notices
Explorer Audio & Navigation Audio and navigation systems. CD, DVD, MP3, GPS, Video, Mobile Computer, Speakers, Amplifiers.
Amp gain question
Reply
Thread Tools
Old 09-04-2003, 09:33 PM   #1
Sublime0069
Nutley, NJ
99 Explorer XLT
Vehicle Specs
(Original Poster)
Amp gain question
Ok, here's my current setup. Factory HU on 99X. SpeakerLevel->LowpassRCA adapter for the RCA's going to my amp. Bazooka EL1500 amp w/ dual 10" Infinity 1030W's.
When I was installing bass blockers, I noticed that if I adjusted the fade/balance in any way, the subs started hitting like 10X harder. Can this damage anything? I'm assuming the way the adapter is patched is causing something similar to a secondary gain? Subs are rated at 1000W max each and the amp only maxes @ 600W, so it shouldn't blow. And it doesn't sound like noise, which I know will damage subs.
Any ideas if this could be potentially harmful?
__________________
http://geocities.com/sir_subby/truck.html
Sublime0069 is offline   Reply With Quote
Old 09-05-2003, 04:48 AM   #2
wvsquirrel
Cocoa, Florida
'97 Sport
Vehicle Specs
Since you used a LOC, the fade will play a key role in the signal to the amps. It's just like when you adjust the fade all the way forward, the front speakers get louder because you are increasing the signal to them while decreasing the signal to the rears. If you adjust the Fade more to the rear, then your rear speakers, as well as your external amplifier since it is receiving it's input from the rear speaker leads, will be receiving a stronger signal.
As long as you had the gains properly adjusted at 0 Fade and 0 Balance, then you should be fine. If you start to hear distortion from the subs, then either adjust the Fade a little more to the front or decrease the gains a little.
__________________
Squirrel
If its too loud, then you're too old
Alpine CDA-7995 headunit, (2) 5.25" Infinity Kappa 50.5cs's, (2) 5x7" Infinity Kappa 572.5cf's, (2) Kenwood KAC-649S amps running the Infinity's, (2) Rockford Fosgate RFD2112 Punch HX2's, (1) Rockford Fosgate Power 1000bd amp running the HX2's
wvsquirrel is offline   Reply With Quote
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
