nkrax
- May 9, 2001
- Colorado
- 1998 xlt 4x4
Greetings,
I have just replaced my serp belt because of a squeeling issue. The problem was imediately corrected and all was fine...until a month later when a chirp...chirp...chirp sound crept under my hood. Unlike the squeeling noise, the chirping does not go away after 5 to 10 seconds. It is there all the time (i guess i should say most of the time). I took a look under the hood and noticed that my tensioner pulley was moving in a side to side motion (the natural path the pulley moves as if you were releasing the tension to take the belt off). The pully was probably moving back and forth about 1/8th to 1/4 of an inch (the movement was easily visible). Do you all think it is the tensioner that has gone bad, or is that kind of movement normal? How do you really know if your tensioner pulley has gone bad?
thanks for any and all help!
Nate
Nate
