blakemiller
- November 7, 2002
- San Diego, CA
- '94 Sport
I've got a 94 Explorer Sport, 130k miles - no major overhauls, some routine maintenance.
I'm having engine troubles once again, so put my scanner to it. Engine Off test came up with Fuel Pump Circuit Open in Stored Memory. I replaced the FO Pump Relay for good measure, and cleared the code.
When I do the Engine Running Test, the only code I get is a 411, which is a "can't hold low RPM" (or similar - don't have my book here w/ me now). Does this mean it can't test any further?? Cause the engine is still running poor and there are no more codes. I've cleaned MAF, changed air filter, etc. etc. but still no go. I haven't done the O2 sensor, as it was replaced recently.
My engine is 'puttering' and has almost no power at times. Even stall it at stop lights at times. Sometimes it sounds like it's backfiring every once in a while. It seems electrical, as every once in a while, it seems to be running okay. Feels like a cylinder misfiring or the computer way out of wack. Any thoughts??
Some history, about 1 month ago when starting it cold, i heard a bang/pop from under the hood, and then a bunch of smoke bellowed from under hood. I popped the hood and the only thing I could find was one of the caps on a small manifold/pipe thing (w/ about 5 small tubes coming out, toards the left/rear of the manifold) had popped off and fell to ground. If I remember, there was some smoke/fumes coming out of the small open inlet. I put the cap back on.
Further, I pulled the Charge Air Temp sensor from the intake manifold, and found it to be completely coated w/ dirty oil. Is this okay? To have oil residue in the intake manifold??
