Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Modified Explorations!!
Notices
Modified Explorations!! Closed to new posts. Place new posts in our new model year appropriate forum
Wheel bearings torq spec per size tire.
Thread Tools
Old 09-10-2003, 10:44 AM   #1
Positive Vibes
Santa Cruz, Ca
Positive Vibes's Avatar
'94 XLT
Vehicle Specs
(Original Poster)
Ok tried a search and had over 700 threads. I browsed thru a few but didn't find much. I know this question has been asked many times. I'm still having my right front tire wheel bearings come loose all the time. I was hoping to get a thread going that is easy to read. What is everyone torqing there inner and outers to?? I know that if we over tighten them the bearings wont last very long and if we under tighten them the dam nuts come loose. So what torq specs is everyone using and for what size tire? Or if there is a good thread on this already just lead me to it. Thanks people.
__________________
'94 XLT, 5.5" superlift, cat back flowmaster, KKM, custom rocksliders, 33X12.5 XTerrains, 4.10's, custom bumpers, Detroit in 8.8, on board air, ARB locker in front winch,etc.
What is greater than God, More evil than the devil, The poor have it, The rich need it, And if you eat it, you'll die?
Positive Vibes is offline
Old 09-11-2003, 12:18 AM   #2
Bashman
Elite Hornet Handler
Trenton, Ontario
Bashman's Avatar
09 Wrangler Unlimited now
Vehicle Specs
The torque specs are different for manual or auto hubs or 2wd.
2wd: initial 17-25 ft/lbs, back off 1/2 turn, final 18-20 in/lbs
Man: initial 35 ft/lbs, back off 1/4 turn, final 16 in/lbs. The outer locknut is torqued to 150 ft/lbs
Auto: initial 35 ft/lbs, back off 1/4 turn, final 16 in/lbs
Remember to spin your front disks while torquing as this helps in seating the bearings and don't forget the little key. If your nuts are still backing off you probably have a worn spindle. These torque values don't change with tire size but a larger tire will obviously increase the wear rate on the components.
__________________
I'm more worried about our beer supply. After this case of beer and the case of beer in the fridge, we only have one case of beer! Barney Gumbal.
T.T.F.N.
Bashman is offline
Old 09-11-2003, 10:16 AM   #3
Positive Vibes
Santa Cruz, Ca
'94 XLT
Vehicle Specs
(Original Poster)
Very nice info Bashman, thanks. I do have Warn manuals. I don't think I've been tightening the outer enough. I will double check today. Thanks again!!
__________________
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
