Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > General Explorations!!
Notices
General Explorations!! Closed to new posts. Place new posts in our new model year appropriate forum
Thumping while driving
Thread Tools
Old 09-18-2003, 01:09 PM   #1
Smurfslayer
Northern Virginia
'91 EB
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Question Thumping while driving
Lately, about the last week, I've been noticing an increasing 'thump' as I drive. I noticed it first, and still, most prominently on deceleration. It's rhytmic, and seems to be proportional to driveline speed. It's a '91 EB 4x4. It's not engine I don't think - once the valve clatter stops, and the startup 'knock', when it warms up, there's no 'other noise' while not under load. During a non congested stretch, I eased the truck into neutral, and it still continued to thump. I got under the truck without ramps & looked around with a light, I didn't see anything loose that I could easily identify, I grabbed & yanked on the drive shafts, and they felt tight. Wheels & tires looked ok & they weren't 'mudded up'. I can't notice the symptom until about 25 mph, it doesn't seem as bad while accelerating, and the brakes almost seem to 'quell' the symptom a little...
Any ideas?
__________________
Dave Yates
'91 4x4 EB Explorer / '01 Lightning / '90 ZX11
NMA / AMA / NRA
Smurfslayer is offline
( Join the Elite Explorers )
Old 09-18-2003, 01:32 PM   #2
KPT
NC
'95 XL 4x4
Vehicle Specs
Quoted: 0 Post(s)
Could be a warped rotor. You'd be able to tell if the sound was coming from the driver or passenger side though.
KPT is offline
Old 09-18-2003, 02:07 PM   #3
Smurfslayer
Northern Virginia
'91 EB
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
hmmm...
The rotors are fairly new - probably less than 4k miles, and about 7 months... Which is certainly no guarantee...
There's no brake pulsation though. I checked the exhaust too, and while it's not rock solid, it doesn't show signs of impacting that I can see. I'm going to put her on ramps to check, once the hurricane subsides...
Thanks, all input appreciated.
__________________
Dave Yates
NMA / AMA / NRA
Old 09-18-2003, 02:10 PM   #4
Chew_12
Working
Chandler, AZ
Chew_12's Avatar
'93 XLT
Vehicle Specs
Quoted: 0 Post(s)
Radius Arm Bushings?
__________________
Matt
KKM Intake, Ravin Muffler, Silverstar Lights,Apten Dual Chip - BROKEN, Panasonic 3600 HU, Herculined Rockers, 5.5" SuperRunner SuperLift, SOA Rear , 33" Xterrians, and Black Rock Crawlers
Broken Arrow and Sodier's Pass 4x4 Pics
Chew_12 is offline
Old 09-18-2003, 02:34 PM   #5
Smurfslayer
Northern Virginia
'91 EB
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
maybe...
I'm pretty sure this truck is all stock, right down to the fluids ( except oil & trans fluid ). I bought it used a couple years back... My 1st thought(s) were U joints, but they didn't seem to have play...
__________________
Dave Yates
NMA / AMA / NRA
Old 09-18-2003, 03:28 PM   #6
Majisto
Austin, Texas
2000 XLT
Vehicle Specs
Quoted: 0 Post(s)
Sounds like your tires may be out of balance.
__________________
2000 Explorer XLT V-6 SOHC -- Ol' Dependable. 180,800 miles
2002 Volvo S80 T6 -- 70,100 miles
2000 Contour SE -- 67,000 miles
Majisto is offline
Old 09-18-2003, 03:40 PM   #7
Smurfslayer
Northern Virginia
'91 EB
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I don't _think_ there's an out of balance tire, the ride quality hasn't diminished, there's no shimmy, no shake, no steering wheel jumping. Plus, the thumping is something that you can hear, as well as feel 'through' the truck. I checked the tires for signs of an imminent blow out, but found none, and a subsequent ride wasn't telling of that either. I'll still give the wheels & tires another look...
__________________
Dave Yates
NMA / AMA / NRA
Old 09-18-2003, 03:52 PM   #8
MrShorty
Spanish Fork, UT
92 XLT and '87 Bronco II
Vehicle Specs
Quoted: 10 Post(s)
Auto hubs going bad? Engage the transfer case long enough to engage the hubs, then disengage the t-case without disengaging the hubs. See if the noise goes away.
__________________
Mr. Shorty
92 XLT 4x4
87 Bronco II XLT 4x4
'98 Chev K1500 Suburban SLT 4x4
MrShorty is offline
Old 09-18-2003, 04:07 PM   #9
Majisto
Austin, Texas
2000 XLT
Vehicle Specs
Quoted: 0 Post(s)
I had a thumping noise from the tires when I found out my tire pressure was VERY low.
__________________
Majisto is offline
Old 09-20-2003, 10:54 AM   #10
Smurfslayer
Northern Virginia
'91 EB
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
hubs... there's a thought.
I'll give the tires a check as well, and take her around the block engaging the trans case... That was on the agenda, but I wanted to do it close to home just in case...
Thanks again...
This is the 1st opportunity I've had since the 'cane. I lost power for 36 hours...
__________________
Dave Yates
NMA / AMA / NRA
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
