Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > General Explorations!!
Notices
General Explorations!! Closed to new posts. Place new posts in our new model year appropriate forum
Heat Shield Rattle!!! How to fix?
Thread Tools
Old 10-02-2003, 07:54 AM   #1
jsun
Calgary, Alberta, Canada
99 Explorer Sport SOHC 4x
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
CAN Heat Shield Rattle!!! How to fix?
Peeps,
I have noticed a rattle under the truck at cold idle after already having the engine pulled to replace the timing chain guides and cassettes. As I crawled underneath I had noticed the rattle to be coming from the muffler heat shield.
The Q is.... Should I just remove the heat shield or is there a fix to this that someone can recommend?
Thanks in advance!
J
__________________
J-Sun...
jsun is offline
( Join the Elite Explorers )
Old 10-02-2003, 08:00 AM   #2
Lifted95X
The Xplorer U Luv to H8
EASTPOINTE, MI
Lifted95X's Avatar
03 4.6 Mounty
Vehicle Specs
Quoted: 0 Post(s)
Just take it off.
__________________
03 Mounty and an 05 Evo
Lifted95X is offline
Old 10-02-2003, 09:49 AM   #3
CADDYBILL
Broad Channel Queens NY
'94 EDDIE BAUER/ sold
Vehicle Specs
Quoted: 0 Post(s)
You could also get a big hose clamp from the plumbing supply and wrap it up. That's whats holding mine on.
__________________
Caddybill
'94 EDDIE BAUER
K&N, AutoZone Shackles, Skyjacker 2inch Lift, 31's (SOLD)
Long Island Dreamboats
CADDYBILL is offline
Old 10-02-2003, 10:49 AM   #4
woodychitwn
Chicago, Illinois
1994 Limited
Vehicle Specs
Quoted: 0 Post(s)
I thought I had the same problem, so I took off the heat shield, and the rattle is still there. To make it worse, the first time I drove through cold water with a hot exhaust, it snapped in two. And I'm still trying to track down the noise. In short, I'd double-think removing the heat shield.
woodychitwn is offline
Old 10-02-2003, 10:57 AM   #5
Lifted95X
EASTPOINTE, MI
Lifted95X's Avatar
03 4.6 Mounty
Vehicle Specs
Quoted: 0 Post(s)
Quote:
That shouldn't happen. What about when it rains, or hits puddles...the heat shield does not cover your whole pipe.
__________________
Old 10-02-2003, 11:17 AM   #6
DeRocha
NEX Vice President
Brockton, MA
DeRocha's Avatar
'93 XLT 4x4
Vehicle Specs
Quoted: 3 Post(s)
If the heat shields are in good shape then I would recommend the hose clamp method. (this is what a Ford dealer would do). Otherwise I would remove them if they're rotted out...
Your pipes would need to be in poor shape combined with a speedy trip through a deep puddle to cause one to break...Just my $0.02...
__________________
John D-"Search first, Ask questions later" & "You can have my Explorer when you pry the keys from my cold dead hands." <<<Forum Rules >>>*My Truck*
4x4 Trouble Shooting Guide
See how cars work Axle and tire calculators U-joint replacement info/pics
Repair info NEX-New England Explorers NEX: Club Events
DeRocha is offline
Old 10-02-2003, 11:55 AM   #7
alphabets13
alphabets13's Avatar
2004 Mountaineer Premier
Vehicle Specs
Quoted: 0 Post(s)
i had this problem recently and i thought it was my heat shield rattling. it wasn't. at the front of the leaf springs, the front meaning the part you can see if you get down and look on the side of your X right in front of the rear tires, there is a bracket of sorts that is there to hold the leafs together. i think it's really nothing but a precaution i guess. anyway, it was sliding around a few inches back and forth and that was the rattle. i placed in in one spot and jb welded it all around. now it's firm and problem is better than it was anyway, and no rattle. hope this helps.
alphabets13 is offline
Old 10-02-2003, 12:43 PM   #8
jsun
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Great feedback gang!!!
Will try the strap method seeing as though the shield it self is in fairly good shape...
What type of hose straps are these? & where can I buy them(auto/home hardware shops)?
Also, I will check into the leaf spring clamps and such to ensure all is "good & tight"...
Bottom line is...I'll be under the truck this weekend shaking the heck out of everything to ensure I have this fixed!!!
Cheers,
J
__________________
J-Sun...
jsun is offline
Old 10-02-2003, 02:51 PM   #9
CarFreak146
Shawnee, Kansas
'94 Explorer XLT
Vehicle Specs
Quoted: 0 Post(s)
oh the first gens (not sure about the newer models) there is also a heat shield on the downpipe, that was rattling on mine. I had my muffler guy tac weld it back to its bracket when I had my muffler installed. It has since came loose and is doing it again though. but anyway, enough of my useless dribble, check the heat shield on the downpipe while your at it.
__________________
Ryan
RIP:: '94 Explorer Leaf Sprung SAS... Full Width HPD44/9"; 5.38s, Locked F/R; 38.5/14.50x15 TSL SXs; C4/Twin-Sticked Dana 20, all Mall Rated
'92 Ranger... 4wd, 2.3, 5spd, Explorer Buckets and Console, 2" Lift, 31's, Flat Black... WAAAAAYYYYY too slow!
CarFreak146 is offline
Old 10-03-2003, 06:07 AM   #10
DeRocha
NEX Vice President
Brockton, MA
DeRocha's Avatar
'93 XLT 4x4
Vehicle Specs
Quoted: 3 Post(s)
Wrap a string around the heat shield and then measure the string to see the approx clamp length you will need.
Get the hose clamps at a hardware store (Home depot or Lowes). They are stainless steel and will be in the plumbing dept.. They come in various sizes, but they can be attached to one another to make any size clamp you need... Don't overtighten the clamps when in place, otherwise you will crush the shield onto the exhaust negating the positive shielding effect.
__________________
DeRocha is offline
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
