Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Elite Explorer 911!
Notices
Elite Explorer 911! 911! is for situations where your truck is currently out of commission and the owner is in a crisis situation. Members will try to answer your questions asap, no time frame is guaranteed. Only Elite Explorers can post new threads in this forum
Auto Trans slipping
Reply
Thread Tools
Old 11-17-2003, 08:55 AM   #1
Rugger
The Colony, Texas
1999 2 Door
Vehicle Specs
(Original Poster)
Unhappy Auto Trans slipping
Yesterday I serviced my Auto Trans. Pulled the pan and replaced the filter.......................
When I was done, I noticed two small o-rings in the replacement filter box. "ARGHHHHHHHHHHHH", but the vehicle drove fine.
This AM, the tran slips. Is the bad seal between the filter enough to cause this issue?
Rugger is offline   Reply With Quote
Old 11-17-2003, 12:11 PM   #2
Opera House
Cincinnati, OH
97 Explorer XLT
Vehicle Specs
Yes
You are sucking air into the system which lowers pressure. This can cause slipping. Others have also experienced this problem when updated filters are used that requires a shorter filter mounting screws and the filter drops down after a hundred miles.
__________________
Rule #7: Believing and seeing are often both wrong. (FOW)
02, 97, 92 Explorer XLT 4X4 4.0L
Opera House is offline   Reply With Quote
Old 11-19-2003, 02:44 PM   #3
Rugger
The Colony, Texas
1999 2 Door
Vehicle Specs
(Original Poster)
When you use the correct parts, things turn out better.
I have now replaced the filter and fluid in my automatic transmission twice. But the good part is that it is working perfectly.
Thanks for your help.
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
