Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Modified Explorations!!
Notices
Modified Explorations!! Closed to new posts. Place new posts in our new model year appropriate forum
A Question about body lifts
Thread Tools
Old 11-20-2003, 06:23 PM   #1
yosh18981898
Chana IL
92 sport 4x4
Vehicle Specs
(Original Poster)
How hard is it to install a 2-inch body lift on a first gen. 2-door. Can I do it by myself in my driveway without any special tools?
yosh18981898 is offline
Old 11-20-2003, 09:47 PM   #2
TheRookie
Traveling SAS guru
West Chester PA
TheRookie's Avatar
91 explorer xlt
Vehicle Specs
Depends on experience and tools. Chances are on a first gen the body mount bolts arent going to want to come out. The easy cure it to heat them up till they glow a nice cherry red. The draw back is you will probably melt most of the mount unless experienced with such an act. I would go ahead and nuy the new body mounts from james duff if you want to do this. there is going to be sme modification doing this. All a matter of tools and experience like I said. Usualy (not to be mean) If you have to ask its probably out of your league. Kinda like when someone asks the price of an E55
TheRookie is offline
Old 11-20-2003, 09:53 PM   #3
88vert
clinton,iowa
94 unlimited
Vehicle Specs
A 2 inch suspension lift would be alot easier
88vert is offline
Old 11-22-2003, 03:21 AM   #4
ExplorerX91
Yakima, WA
91 XL
Vehicle Specs
try searching there are literally 1000s of Body Lift threads on here but to answer ur question, im 16 and so is my friend, although we knew the basics of trucks, lifting,cars we knew nothing about the body lift with nothing but rachets we put on a 3 in BL on my 1st gen 4dr im pretty sure the 4 and 2dr are the same for body lifts not exactly sure tho, just follow directions and look up stuff u may run into.
__________________
91 Ford Explorer XL 5spd, 3" PA BL, Flowmaster 40 series, 2.5" piping, tinted, 32x11.5 WC TXR's, halogens, Midland cb, system mods
http://www.explorerforum.com/forums/showthread.php?s=&threadid=94777
ExplorerX91 is offline
Old 11-22-2003, 09:00 PM   #5
Redrig
Gettysburg,PA
Redrig's Avatar
1997 Mountaineer
Vehicle Specs
My thoughts exactly.
__________________
http://www.myspace.com/exforce
Redrig is offline
Old 11-24-2003, 07:59 AM   #6
yosh18981898
Chana IL
92 sport 4x4
Vehicle Specs
(Original Poster)
I don't really want a suspension lift because they are more expensive to buy and raise the center of gravity too much. Even at stock height, trying to make a fast right is like trying to steer a barn around a sharp curve.
All you have to do to install a body lift is pop off the frame mount bolts, slide in the two inch spacers, and bolt every thing back down, right?
Old 11-24-2003, 05:33 PM   #7
TheRookie
Traveling SAS guru
West Chester PA
TheRookie's Avatar
91 explorer xlt
Vehicle Specs
OK please search some. The answer is NO but you would find that in a search
Old 11-24-2003, 05:38 PM   #8
88vert
clinton,iowa
94 unlimited
Vehicle Specs
Whats so hard about coil spacers and shackles Suspenion lift is the way to go
88vert is offline
Old 11-24-2003, 06:42 PM   #9
Skeets'91EB
Tulsa, OK
'91 Eddie Bauer
Vehicle Specs
I know what you mean about steering a barn. But it really isnt going to matter that much if you raise the the center of gravity 2 inches, because you're going to be stiffening the suspension anyway, so the truck wont lean as much when you turn. I want to lift my explorer a bit just to reduce some body roll and make it a bit sturdier than stock. If you REALLY dont wanna do a suspension lift, then...ee swaybars?!?! i've heard really good things about those.
__________________
Supercharged 4.0L OHV, Alarm/Keyless, KKM, Tinted 20%, Ventshades, Pioneer DEH-P7400MP, TPS mod, BBK 66mm TB, EE X-Spec Swaybars, Gibson 2.5" Exhaust, Sylvania Silverstars, Coil Spacers/WAR-153s, 15x8 Ultra Rocas, 31s, Euro Gauges, MSD wires
Future mods: 700R4, Rear-disc Kit
Skeets'91EB is offline
Old 11-24-2003, 10:26 PM   #10
TheRookie
Traveling SAS guru
West Chester PA
TheRookie's Avatar
91 explorer xlt
Vehicle Specs
WHAT?!?! Few lifts will reduce body roll. And how are you replaceing a lift with a sway bar? I hope I am just reading your post wrong If your goal is less roll then go with big burly sway bars and polyurethane bushing all around.
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
