#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Offroad Tech Forums > Offroad Explorer - Ranger Projects > Explorer - Ranger Shocks, Suspensions, Lift Kits
Notices
Explorer - Ranger Shocks, Suspensions, Lift Kits Ford Explorer and Ranger chassis related posts. Get help choosing the right shock absorber and aftermarket suspension for your Explorer or Ranger based vehicle.
Interested in lifting a 95' ford explorer 6"?
Reply
Thread Tools
Old 12-13-2003, 02:11 AM   #1
Fordtrucks2k3
Sykesville,MD.
'95 Sport
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Unhappy Interested in lifting a 95' ford explorer 6"?
I have been interested in lifting my explorer 3,4,or 6" and im not sure what kit to buy. Im not sure if 3" is enough. I checked out superford.org and someone said that you can get a 3" lift for $150. Im kind of on a budget but i still cant find any lifts for the 95 explorers and some one help?
Fordtrucks2k3 is offline   Reply With Quote
( Join the Elite Explorers )
Old 12-13-2003, 02:15 AM   #2
section525
sextion525
Red Bluff, Ca
section525's Avatar
1975 Ford Bronco 4x4
Vehicle Specs
Quoted: 21 Post(s)
Superlift makes a 4" suspension kit. $1400ish
Trailmaster makes a 4" suspenion lift too
You can use a 2" or 3" 95-97 Ranger body lift $150
You can add shackles to the rear (1 1/2") for $50
You can add add-a-leafs to the rear (1 1/2") for $30
You can adjust your torsion bars (for the front) up to 2"
There's lots of ways to lift your '95. This is the place to learn all about them. I recommend you use the search function and get researching!
Welcome!
__________________
Support the Forum
'13 3.5 Explorer
'75 5.0 Bronco
'04 6.0 Super Duty
section525 is offline   Reply With Quote
Old 12-13-2003, 02:18 AM   #3
Heath
Elite Moderator Intoxicator
Rigby, ID
Heath's Avatar
00 Excursion (THE BUS)
Vehicle Specs
Quoted: 6 Post(s)
You left the chat so fast I didn't get a chance to tell you... LOL...
__________________
Rigby, ID
"Never fight an ugly guy, he has nothing to lose"
Mugshot Updated 8/6/10
To support the site and upgrade to an elite membership, Click Me!
Heath is offline   Reply With Quote
Old 12-13-2003, 04:44 PM   #4
Blee1099
Evil Asian
Elkridge, MD
Blee1099's Avatar
91
Vehicle Specs
Quoted: 10 Post(s)
I recommend getting a performance accessories 3" body lift for a Ranger.. I believe the part # is 853 and doing a shackle & TT to get roughly 5" of lift. That's what I plan on doing after the new year. Btw, did anyone get new cv axles after doing the body lift? I know the added height adds stress to the cv's angles.
Blee1099 is offline   Reply With Quote
Old 12-13-2003, 04:56 PM   #5
section525
sextion525
Red Bluff, Ca
section525's Avatar
Vehicle Specs
Quoted: 21 Post(s)
The body lift doesn't affect your CVs. Did you mean the torsion twist? If so, I don't know of anyone who has needed to CVs specifically from the TT. But I know Jefe use to change his with every oil change. But he's a special case.
__________________
Support the Forum
'13 3.5 Explorer
'75 5.0 Bronco
'04 6.0 Super Duty
Old 12-13-2003, 05:01 PM   #6
Blee1099
Evil Asian
Elkridge, MD
Blee1099's Avatar
91
Vehicle Specs
Quoted: 10 Post(s)
Yeah I meant TT. Well I know replacing the cv are a piece of cake, I've done em before on my old car back when I was 16. It would make sense to look at the option when I do my lift after the New Year. I've seen mid 90's Broncos with extended drive shafts due to a lift kit being installed. It'll have to be a custom CV axle.
Old 12-13-2003, 06:55 PM   #7
Hokie
Hokius Maximus
Denver, CO
Hokie's Avatar
'98 TJ Sport
Vehicle Specs
Quoted: 1 Post(s)
Quote:
__________________
Brett
I get paid to play with Cummins engines
My old '98 MTNR - 5.0 V8 4x4 My old '99 Sport
Hokie is offline   Reply With Quote
Old 12-13-2003, 07:02 PM   #8
white96x
Rancho Cuc,Ca(home) SLO,Ca(school)
1997 E.B.
Vehicle Specs
Quoted: 0 Post(s)
you guys forgot about the Pro Comp spindles. it's a 3" lift KIT (includes add-a-aleaf and shocks) for ~650. Also, keep in mind that the superlift and Trailmaster are for 4x4's ONLY....it doesn't mention in your post if you are 4x4 or not so i don't know....good luck
__________________
'97 5.0 V-8 2wd, SpinTech, K&N FIPK, Front:Camburg 6.0 with Radflo 2.0x8.5" coilovers, Rear: Deaver's, 33x12.50 BFG AT's, 15x8 Rockcrawlers, 4.56's.
white96x is offline   Reply With Quote
Old 12-13-2003, 07:03 PM   #9
Alec
Elite Moderator
Houston, Texas
Alec's Avatar
2008 JK
Vehicle Specs
Quoted: 0 Post(s)
Re: Interested in lifting a 95' ford explorer 6"?
Quote:
Welcome!
What's your budget and what size tires you want to run?
__________________
Alec "Dr. Candlepower" Rosenbaum
Daily: 2008 JK
Gone: EE "Splat", 2003 VW GTI VR6, 85 Bronco project
Alec is offline   Reply With Quote
Old 12-13-2003, 07:15 PM   #10
section525
sextion525
Red Bluff, Ca
section525's Avatar
Vehicle Specs
Quoted: 21 Post(s)
Quote:
The Trailmaster will work on either since it uses the stock spindles... and you could run the superlift 4x4 spindles on a 2wd with a little bit of modding. That is if you want to drop $1400 on either of them.
__________________
Support the Forum
'13 3.5 Explorer
'75 5.0 Bronco
'04 6.0 Super Duty
Old 12-14-2003, 01:05 PM   #11
springtensi0n
norwich, ct
95 XLT
Vehicle Specs
Quoted: 0 Post(s)
im running the explorer express 'lowering kit' and i've been hitting snow banks left and right [with my front bumper]. so yesterday, i put them under the axle to get a little lift out of it. is it safe to use shackles in conjunction with this? im not looking for anything perminate, just for the winter.
springtensi0n is offline   Reply With Quote
Old 12-14-2003, 01:11 PM   #12
Fordtrucks2k3
Sykesville,MD.
'95 Sport
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Arrow Reply
I consider getting 3" body lift but someone told me its not as good as suspension lifts. It doenst look as good? you can see through the wheel whells straight accross? i prob. run 30's-31's
Not sure yet.
i want a 3" body but if it doesnt look good and benifit me at all im not sure what i should do.
Old 12-14-2003, 01:14 PM   #13
dman726749
Greenwood Indiana
96 xlt
Vehicle Specs
Quoted: 0 Post(s)
if you are only going to run 30 or 31" tires then forget about a body lift. just put some shackles out back and do the tt up front for about 2" of lift. it will look real mean, plus its alot cheeper and less hassel than a bl.
__________________
Dustin
96 XLT 2" tt and war shackles, 3" b/l 33" X-Terrains, Custom Snorkel Sold
Dman726749's 96 X!!!
2006 F150 FX4 Super Crew
Indianapolis Indiana Senior Portrait and Wedding Photography
dman726749 is offline   Reply With Quote
Old 12-14-2003, 01:17 PM   #14
section525
sextion525
Red Bluff, Ca
section525's Avatar
Vehicle Specs
Quoted: 21 Post(s)
Here is a side view of mine with a body lift:
It doesn't look as clean as a SL.. but what can you do..
__________________
Support the Forum
'13 3.5 Explorer
'75 5.0 Bronco
'04 6.0 Super Duty
Old 12-14-2003, 01:25 PM   #15
Jefe
Clarksville, TN
'00 XLT 4x4
Vehicle Specs
Quoted: 0 Post(s)
Quote:
LOL Funny, but true
front locker + extended droop + cheap half-axles = < 10k mile CV life
To help you see how much lift and what size tires you really want, go to this link:Jefe's Mods There I have pics of my truck in its different stages.
__________________
'00 Explorer XLT - Sold
'01 Focus SE
Jefe is offline   Reply With Quote
Old 12-14-2003, 01:31 PM   #16
section525
sextion525
Red Bluff, Ca
section525's Avatar
Vehicle Specs
Quoted: 21 Post(s)
I was going to get on you to update cause I was there a couple days ago and it was all old news.
__________________
Support the Forum
'13 3.5 Explorer
'75 5.0 Bronco
'04 6.0 Super Duty
Old 12-15-2003, 12:09 AM   #17
Stic-o
Elite Movie Star
Tujunga, CA
Stic-o's Avatar
'99 XL 4x4 & '16 XLT
Vehicle Specs
Quoted: 181 Post(s)
Talking My truck is in
between phase 2...
and phase 3....
of the Jefe Explorer modifcation 5 step progam.
(however I cheat I buy up jefe's old stuff )
Thank You Jefe
this add was paid for by people jealous of jefe's truck
__________________
The JP Mobile ~'99 Explorer XL 4X4 * The Mall Crawler '16 Explorer XLT
The Tow Rig ~ '01 F250 Crew Cab 4X4 * The "Commuter" ~ '15 Focus ST
Stic-o is offline   Reply With Quote
Old 12-15-2003, 01:06 AM   #18
Jefe
Clarksville, TN
'00 XLT 4x4
Vehicle Specs
Quoted: 0 Post(s)
The Jefe 5 step progam
ROFL
Hmm. . .time for a signature change
Btw, the IMG tag needs to link to the picure, and not the page the picture is on.
__________________
'01 Focus SE
Old 12-15-2003, 12:58 PM   #19
Stic-o
Elite Movie Star
Tujunga, CA
Stic-o's Avatar
Vehicle Specs
Quoted: 181 Post(s)
Talking here you go jefe..
Just for you!
The 5 step thread
__________________
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
