glfredrick
- January 25, 2003
- Sheboygan, WI
- 2014 Explorer Limited
Help from someone that knows these transmissions!
I ordered a rebuilt 5R55E and when it arrived it did not have a place to put the front externally mounted sensor for the computer. (I think that it measures the high gear hub speed.) It does have a place to moung the rear sensor (low/reverse hub).
I think that the service department is going to try to tell me that the transmission will work without this sensor, but I am having a hard time believing that.
So, does the transmission NEED this front sensor or not? Do the later model cases (98 and up from what I can find) work in place of the 97 model? What will happen if I end up installing this tranny and the sensor does not read? Will I get error codes, and will it mess up anything?
What sucks is that I specifically TOLD them that I had the 97 model with the EXTERNAL SENSOR! It is even printed on the invoice!
So, Oprera House, or anyone with experience with these models, please respond.
Thanks!
Thanks!
