Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Offroad Tech Forums > Offroad Explorer - Ranger Projects > Offroad Drivelines
Notices
Offroad Drivelines Ford Explorer and Ranger Transmissions, Transfer Cases, Driveshafts and Axles.
Tapping drain plug into front Diff?
Reply
Thread Tools
Old 12-20-2003, 06:39 PM   #1
Vozar
Was Fordbeast98
Murfreesboro,Tennessee
Vozar's Avatar
Vehicle Specs
(Original Poster)
Everyone knows getting the fluid changed in the front diff is a PITA . I know some one out there has at least tried this and was wondering if it was was possible. Is it hard to tap a drain plug in the front diff if you have the right equipment?. Whats the best place to put it.? ANyone done it yet or have any pics of one tapped? I am serious about doing this and could use the help. Thanks, Matt
__________________
99.5 F-250 ecsb 4x4 (FOR SALE)
2000 f-250 rclb 2wd 6spd
1994 explorer 4x4 1-tons,42's,302,c-6,1356/205
1998 explorer(in pieces)
2003 explorer 4dr eddie bauer(wifes)
www.dixiecrawlers.com www.swampsdiesel.com
Vozar is offline   Reply With Quote
Old 12-25-2003, 12:21 AM   #2
Vozar
Was Fordbeast98
Vozar's Avatar
Vehicle Specs
(Original Poster)
come on, someone has had to have done this
__________________
Old 12-25-2003, 10:00 AM   #3
Hotweels
Calgary,AB
'92 EB
Vehicle Specs
I have only been under the front end of a 95+ explorer once and i dont remember what it even look's like BUT! i dont imagin a drain plug would be that hard to install, just get a decent size pipe fitting plug and the corosponding tap and have at er... my only concern would be getting drill shavings inside the pumpkin so i would highly recomend you remove the whole 3rd member first.
I was thinking about doing this on my 92's D35 TTB but i found a better soloution
__________________
D44/9" open/spool
36" TSL SX's
Warn 8274
C5-B&M Megashifter
5.0 Speed Density swap done an running.
Hotweels is offline   Reply With Quote
Old 12-25-2003, 12:47 PM   #4
hvac man
Rifle, CO
hvac man's Avatar
93 Sport
Vehicle Specs
I almost did the same thing when I still had my TTB under there. I was installing my front ARB and thought what the hell, why not put a drain in there. I was going to use a brass pipe fitting and drill and tap the hole but I couldn't fine the fitting I wanted at 9:30 pm so I just put the thing back together and then sold the TTB a few months later It is posible and fairly easy to do. Just make sure you mark where the crossmember is and stay away from it and you'll be golden.
__________________
'94 XLT 4 door- let the adventure begin!
93 Explorer 2-door with some mods R.I.P.
'96 Toyota 4runner SR5
hvac man is offline   Reply With Quote
Old 12-25-2003, 11:43 PM   #5
Vozar
Was Fordbeast98
Vozar's Avatar
Vehicle Specs
(Original Poster)
cool,thanks for the help guys, Matt
__________________
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
