Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Ranger - Mazda B-Series Forum > Ford Ranger - Mazda B-Series Forum
Notices
Ford Ranger - Mazda B-Series Forum Ford Ranger and Mazda B Series forums. The Mazda B2300 B3000 and B4000 are clones of the Ford Ranger, with all systems the same. The only differences are trim and a few body parts. This forum discusses Ford Ranger and Mazda B series specific issues. Owners of the older Mazda B2000 B2200 and B2600 are welcome as well.
Passenger Window Replacement
Reply
Thread Tools
Old 01-03-2004, 11:05 AM   #1
gurnblansten
Ft. Smith, AR
94 Ranger XLT Long Bed
Vehicle Specs
(Original Poster)
My 94 passenger window was shattered during a recent break-in (bastards took my beloved stereo), and I'd like to replace the window myself. Is this easy? I've done it several times on past cars, but not the Ranger. Is it bolted on, or riveted? Any info is appreciated. Thanks.
gurnblansten is offline   Reply With Quote
Old 01-03-2004, 12:30 PM   #2
FourXFred
Masshole
Boston, MA
FourXFred's Avatar
02 EB
Vehicle Specs
on my explorer it was riveted, but i dont know about on my ranger. it was still real easy to replace, just drill the rivets out (which was way easier than it sounds, and it still sounds pretty easy) and slide in the new window. the hardest part was trying to get all of the broken glass out of the doorskin. just go to a junkyard and completely destroy the door of a ranger similar to yours to see how it all works, then take the window and put it in your truck the right way. 1993-1997 rangers should all be the same, both reg and extended cab. later rangers may be the same too, i dont know.
EDIT: when i replaced my window in my ex, i used bolts instead of rivits when i put it back in. it was a lot easier than screwing with my 45 year old rivet gun, and worked just as well. good luck man!
__________________
4.6, RB 3 inch spacers, 265/75 BFG AT's, Brown wire mod, K&N cold air intake. 2ND rear end, 100th wheel bearing.
FourXFred is offline   Reply With Quote
Old 01-03-2004, 01:00 PM   #3
gurnblansten
Ft. Smith, AR
Vehicle Specs
(Original Poster)
Thanks for the info
I wish I had pulled the window myself, so I could see how it's in there, but I bought an already pulled & cleaned one for 45 bucks. Also, I was considering bolting it, since I had done that in the past with success. Thanks for the reply!
Old 01-03-2004, 02:10 PM   #4
RangerX
Moderator
Elite Ranger
Omao, Kauai
RangerX's Avatar
'93 Ranger XLT 4X4
Vehicle Specs
I replaced a window in my 93. I had to drill out the rivet, and replaced it with a bolt, too. It was pretty straightforward. You should have no problems since you've done it on other cars.
__________________
Bill Collins
93 Ranger XLT 4X4
"Beauty is only sheet metal deep."
RangerX is online now   Reply With Quote
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
