| Performance Lighting Aftermarket lighting. Driving lights, fog lights, rock lights, HID, halogen. Make your Ford Explorer light up the night!! |
Thread Tools |
#1 |
Moderator Emeritus
McKinney, TX
76 Bronco
OK, Thanks to the group purchase many years ago, I have a nice set of lights to mount on my ride.
The problem is I don't have the wiring instructions. The Huge White Wire is most likely = Battery / Hot The Huge Black Wire is most likely = Ground There are 2 small wires, 1 White, 1 Black with the round bullet type plugs on them. Where do they go? There is also another small white wire that comes off the toggle switch. Is this a hot or a ground? I'm lost with the little wires right now. Not really sure where they are supposed to go. Any help would be great. Thanks Rob __________________ Rob Robertson The ghost of Explorers past! |
#2 |
Boost Junky
East Hartford, CT
1999 EB 5.0L V8
Lets see here
Huge white wire goes to battery Huge black is ground As for the two small wires with plugs on them they should go to the fog lights ( I need more info on them though to be positive) Small white wire off toggle switch goes to acc power. __________________ Supercharged 1999 Ford Explorer EB 5.0L v8 Supercharger is for sale check out http://www.explorerforum.com/forums/showthread.php?p=1039257#post1039257 |
#3 |
Elite Moderator Emeritus
Greenville, MI
98 Mountaineer 5.0 AWD
Comming off the switch are three wires. Blk.=Ground.
Wht. W/plain or cut end=switch power. Bullet end= to relay. There may be some info on the www.piaa.com site also. __________________ Bill Kemp Mods to come..... 07 Lincoln MKX Clones are people two. |
#4 |
Moderator Emeritus
McKinney, TX
76 Bronco
Still working it...
I have looked at PIAA site a couple of days ago. They said they would fax me the wiring diagram, but nothing has showed up.
The ligths plug into a wiring harness. So there is nothing to run there. The big wires make since and so does the wire coming off the toggle switch. I'm still at a loss of what the other 2 small wires are for. One is white and one is black. They are part of the wiring harness kit, but I have no idea of what there purpose is. Thanks Rob __________________ Rob Robertson The ghost of Explorers past! |
#5 |
Elite Moderator
Houston, Texas
2008 JK
Where are these wires coming from and what connectors do they have again?
__________________ Alec "Dr. Candlepower" Rosenbaum Daily: 2008 JK Gone: EE "Splat", 2003 VW GTI VR6, 85 Bronco project |
#6 |
Greenville, MI
The wire that goes to the relay from the switch may have bullets on both ends which plug into recepters comming out of the relay & switch wire.
The relay is also grounded by a short black wire that usually I ground at the same screw I use to mount the relay. Look at this diagram and fit your pieces to fit theirs. http://catalog.com/susq/other/auxlamps.htm Only difference is that your fuse is in the relay and your switch is also grounded by the black wire . __________________ Bill Kemp Mods to come..... 07 Lincoln MKX Clones are people two. |
| Thread Tools | |
