Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Elite Explorer 911!
Notices
Elite Explorer 911! 911! is for situations where your truck is currently out of commission and the owner is in a crisis situation. Members will try to answer your questions asap, no time frame is guaranteed. Only Elite Explorers can post new threads in this forum
2000 XLT 4.0 won't idle & stalls at times
Reply
Thread Tools
Old 01-17-2004, 09:53 AM   #1
Rickster
Jupiter, Fl
2000 XLT
Vehicle Specs
(Original Poster)
Just a couple time this week, the engine will start but will not idle and stalls. It runs fine if I hold the accelerator peddle to keep RPM’s up, but will not idle on it's own. Next day, it is fine and runs like normal. Then another day it will happen again. It has 71K miles.
Rick...
Rickster is offline   Reply With Quote
Old 01-17-2004, 08:33 PM   #2
i8u
Miami, St. Louis, Roaring Fork Valley
i8u's Avatar
06 SR5 4.7L 4runner
Vehicle Specs
When it gives you trouble again......go out and tap on the idle air control valve. Get back in and I bet it will start. They start to stick somtimes when the get old. It runs when you hold the axcellerator because you are doing the idle air control valves job in a way.
i8u is offline   Reply With Quote
Old 01-20-2004, 12:29 PM   #3
Fausto
atlanta, ga
'00 XLT
Vehicle Specs
I have essentially the same problem. Where is the IAC valve located?
Fausto is offline   Reply With Quote
Old 01-20-2004, 10:23 PM   #4
i8u
i8u's Avatar
06 SR5 4.7L 4runner
Vehicle Specs
It is bolted on to you TB by 2 bolts. There is also an electrical conector. You may have a plastic cover to remove so you can see it.
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
