Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Elite Explorer 911!
Notices
Elite Explorer 911! 911! is for situations where your truck is currently out of commission and the owner is in a crisis situation. Members will try to answer your questions asap, no time frame is guaranteed. Only Elite Explorers can post new threads in this forum
Engine temperature
Reply
Thread Tools
Old 01-24-2004, 03:45 AM   #1
jausa
Stockholm Sweden
Explorer 1995 XLT
Vehicle Specs
(Original Poster)
Engine temperature
Hello i have problems in with my Ford Explorer 1995 XLT.
On the instrument board in the car the temperature is not mowing at all . I have been changing termostat and the engine coolant temperature sensor but nothing happens.
Any idea what to look after. Is there a single connection behind the dasboard ore is it like a "computer" contact.
Jausa
jausa is offline   Reply With Quote
Old 01-24-2004, 10:33 AM   #2
Jason_25
ECX Member
New Bern, NC
Jason_25's Avatar
'95 Explorer "Expedition"
Vehicle Specs
I had the same problem. My temp gauge was pegged all the way as low as it could go. It was not due to a loose connection though. It was a problem with the gauge itself and the only way I could fix it was to replace the left side of the gauge cluster. Yes, there are three wiring cables that slide into the back of the cluster. The temp gauge gets signal from one of them.
__________________
1995 Explorer "Expedition" 4.0 4x4
1987 Bronco II XLT 2.9 4x4
1988 Bronco II XLT 2.9 4x2
1997 Explorer XLT 5.0 4x2
My Truck
Jason_25 is offline   Reply With Quote
Old 01-25-2004, 12:34 AM   #3
Goonbery
Saratoga Springs, Utah
1997 XLT
Vehicle Specs
I had the same problem and the dealer said it was a faulty sending unit. They replaced it and the gauge does move now, although it hardly moves above the C. The dealer had my car plugged into the computer and said the engine didn't get above 164*, so they think somebody changed the thermostat. I guess I will have to replace it with the correct temp and then see if my gauge reads correctly.
Jeff
__________________
1997 Explorer XLT, 4.0L V6, all the goodies.
Goonbery is offline   Reply With Quote
Old 01-26-2004, 02:54 PM   #4
jausa
Stockholm Sweden
Explorer 1995 XLT
Vehicle Specs
(Original Poster)
Engine temperature
Thank You for you good advise and quick reply. Will check the things and i will came back and tell what i found !
Have a nice spring,
Jausa
Old 01-26-2004, 03:06 PM   #5
aldive
Elite In Memoriam
aldive's Avatar
1999 XLT
Vehicle Specs
Same problem here' solution was a new gauge cluster.
__________________
Al Franklin
My truck
My Quest for 30
RIP Al Franklin! 1947-2010. Gone but not forgotten! :(
aldive is offline   Reply With Quote
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
