SR77
- October 29, 2003
- Central NJ
I know that you are suppose to burp the cooling system of air by running the truck with the Rad. cap off after a radiator flush, but should this burp procedure also be done as a maintence step in between cooling flushes to release any air that builds up in the system or will the air in the cooling system just simply rise to the top of the radiator and coolant just has to be added to top it off to replace the air? Does alot of air build up in the cooling system in between flushes that would need to to burped out? Trying to learn more about the cooling system and how to keep in maintaned. Thanks for the help
