Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Offroad Tech Forums > Offroad Explorer - Ranger Projects > Explorer - Ranger Shocks, Suspensions, Lift Kits
Notices
Explorer - Ranger Shocks, Suspensions, Lift Kits Ford Explorer and Ranger chassis related posts. Get help choosing the right shock absorber and aftermarket suspension for your Explorer or Ranger based vehicle.
2000 XLT BODY LIFT?
Reply
Thread Tools
Old 01-27-2004, 05:43 PM   #1
kzman28
kalamazoo,Mi
2002 explorer sport
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
2000 XLT BODY LIFT?
IS THERE A BODY LIFT OUT THERE FOR A 2000 FORD EXPLORER XLT?OR EVEN ONE THAT CAN INTERCHANGE FROM ANOTHER VEHICLE.ALSO IS THERE A BUMPER KIT?
kzman28 is offline   Reply With Quote
( Join the Elite Explorers )
Old 01-28-2004, 03:02 PM   #2
21robbie21
Elite SPort
duluth, ga
21robbie21's Avatar
explorer sport 2001
Vehicle Specs
Quoted: 0 Post(s)
you need a body lift kit for a ranger 98-00 and you will have to make slight adjustments,
"The Ranger kit should have just about everything you need to do it. Some people say they had to buy longer bolts, but i used the ones that came with the kit and all I had to modify was to drill out one mount on each side and use a nut instead. the bumper brackets may not match or you may have to drill new holes for them." Chris4x4Gill2
__________________
2001 xsport
Some Flex pics
My SAS thread
My X
SASed D44 front on 37" Parnelli Jones Dirt Grips
4.88's, Detroit TruTrac in the rear
21robbie21 is offline   Reply With Quote
Old 01-28-2004, 05:35 PM   #3
SplashMan
Cedar Rapids, IA
SplashMan's Avatar
'93 Ranger
Vehicle Specs
Quoted: 0 Post(s)
Performance Accessories makes a series of 3" body-lifts for the 95-01 Rangers. The Ranger is identical to the Explorer from the cab forward so these kits will work on Explorers.
Performance Accessories produces two kits, one for 95-97's and one for 98-01's. The main difference with these kits is the steering extension and bumper brackets. The 98-01 kit will work on ALL 95-01 Explorers with the exception of the steering extension on 95-97's. Here's the catch, you need the steering extension from the 95-97 kit for 95-97's, but the 95-97 kit does not have the correct bumper lift brackets so after a few hit and misses we found it easier to order the 98-01 kit and then specify that you need the 95-97 extension.
Performance Accessories makes excellent kits and are top of the line. Installation time averages around 8 hrs with help from a few friends. The kit price is around $130 which is the cheapest 3" lift around. If you are looking for some lift and on a budget then this is the way to go.
You can also get an additional 1.5" of lift in the front but cranking your Torsion bars up 2". An additional 1.5" for the rear can be gained by swapping your stock shackles for Warriors.
With the Torsion twist by itself you can run 31" tires with no cutting of the body, with the 3" BL you can run 32" tires with no cutting of the body, with the Torsion twist, Warrior Shackles and BL you can run 33" tires with a little cutting on the front wheel-well.
SplashMan is offline   Reply With Quote
Old 12-18-2008, 05:44 PM   #4
areyoukind69
Traverse City, Michigan
2000 Ford Explorer XLT
Vehicle Specs
Quoted: 0 Post(s)
Dk Exp
What about a suspension lift for 00 ford explorer xlt 4wd! How come this year is so hard to find.?
Where is the best place to a complete kit ?
areyoukind69 is offline   Reply With Quote
Old 12-18-2008, 06:10 PM   #5
CCr
Ray ND
'98 XLT, 66 Mustang
Vehicle Specs
Quoted: 0 Post(s)
hard to find cuz no one wants to make them, these are the rollover years. searching thru the forums will net you more info than you ever need so I will point you to superlift and trailmaster suspensions. search them on the forum and you'll get about 500 different threads. body lift is way cheaper. I've done mine already
__________________
1998 Xplodr xlt 4x4: ZAPV X
Team ZAPV
CCr is offline   Reply With Quote
Old 12-18-2008, 09:34 PM   #6
areyoukind69
Vehicle Specs
Quoted: 0 Post(s)
Dk Exp
This place was one of the best priced place besides..JC whitney
Fat Bobs garage
http://store.fatbobsgarage.com/share...urce=shopzilla
Old 12-25-2008, 10:46 PM   #7
wigsplitta
2000 SOHC
Vehicle Specs
Quoted: 0 Post(s)
So will i need a steering extension for my 00 xlt??? Also other than bumper brackets what else will be fabricated? I want to have them made before I start this project.
wigsplitta is offline   Reply With Quote
Old 07-15-2012, 11:39 AM   #8
coreybeaudry904
orange park. FL
2000 / ford /explorer XLS
Vehicle Specs
Quoted: 0 Post(s)
Dk Exp body kit
i am also looking for the same thing i want to make it at least 5 inches
coreybeaudry904 is offline   Reply With Quote
Old 08-25-2012, 02:59 PM   #9
xplorer120
Hurricane, WV
Vehicle Specs
Quoted: 0 Post(s)
I have also been looking for a lift kit for my explorer. i found this one but so far its the only one i can find
http://www.ultimateautoaccessories.c...duct/K494.html
Last edited by xplorer120; 08-25-2012 at 03:02 PM. Reason: i coppied the link from the address bar but it takes you to the home page
xplorer120 is offline   Reply With Quote
Old 08-28-2012, 05:36 PM   #10
slickemhoundd
Glassboro, southern jersey
slickemhoundd's Avatar
1996 Limited 5.0
Vehicle Specs
Quoted: 2 Post(s)
superlift kit is nice and all but for the price new i would say its not worth it. and thats coming from some one that got it for free.... well swapped stock for superlift on 2 trucks in one day but still cash free. find one used or do a tt/shackles till you find one used, try a body lift, against my religion but will clear larger tires. all depends on what you want
__________________
God's country is heaven
Cause you can drive like
HELL!!
1996 Explorer 5.0 Limited-snorkel-4" superlift-tt&shackles-33/12.5/15 MT/R Kevlars-Mechman 270 amp-3 12" subs-2 daylighters, rlc bumper-12k winch-exhaust
slickemhoundd is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
