Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Elite Explorer 911!
Notices
Elite Explorer 911! 911! is for situations where your truck is currently out of commission and the owner is in a crisis situation. Members will try to answer your questions asap, no time frame is guaranteed. Only Elite Explorers can post new threads in this forum
ABS problem !
Reply
Thread Tools
Old 02-07-2004, 01:55 AM   #1
Vozar
Was Fordbeast98
Murfreesboro,Tennessee
Vozar's Avatar
Vehicle Specs
(Original Poster)
ABS problem !
Just recently ive been having ABS problem. at random times i will get that ABS shudder in the brake pedal and when that happens it pulls to the right really hard. THe ABS light has not come on at all. I checked all the lines and the fluid level and they are fine. I could use the info.
-Matt-
__________________
99.5 F-250 ecsb 4x4 (FOR SALE)
2000 f-250 rclb 2wd 6spd
1994 explorer 4x4 1-tons,42's,302,c-6,1356/205
1998 explorer(in pieces)
2003 explorer 4dr eddie bauer(wifes)
www.dixiecrawlers.com www.swampsdiesel.com
Vozar is offline   Reply With Quote
Old 02-07-2004, 02:20 AM   #2
Howard
Moderator
Milton Keynes
Howard's Avatar
1998 SOHC UK SPEC
Vehicle Specs
The first thing to do is to make sure that all your brakes are working ok. It could well be a sticky cylinder. So I would take them all apart and clean them up. If the rears are not working right then you get more front end braking and it could be that which is causing the abs to activate.
__________________
"Be nice to nerds. Chances are you'll end up working for one." Bill Gates
My Explorer
Moderator : Exploring Computers!!, Computer Gaming, Digital Explorations, UK Explorer Owners
Howard is offline   Reply With Quote
Old 02-07-2004, 02:25 AM   #3
Vozar
Was Fordbeast98
Vozar's Avatar
Vehicle Specs
(Original Poster)
Tomorrow im going on a big wheeling trip so i hope i will be alright. After i get back though i will look over the rear brakes. I just replced the rear rotors and pads about a month ago. i did the left side and my friend did the right side. I failed to look over my friends work. I will check them and get back.
__________________
Old 02-07-2004, 02:32 AM   #4
Howard
Moderator
Milton Keynes
Howard's Avatar
1998 SOHC UK SPEC
Vehicle Specs
From the sound of it I would definately start there. We all make mistakes lol.
__________________
My Explorer
Old 02-07-2004, 08:48 AM   #5
Billy177
Redding CT
99 Explorer XLT SOHC 4x4
Vehicle Specs
for now just pull the abs fuse. they should have made a switch for it cause it blows.
maby the 35's are confusing them although this is just a guess
__________________
1999 4.0 Sohc XLT 4x4 3.55 31' BFG MT
Mac Air Intake, High-Flow cats, Excalibrator
Flowmaster 50 Series Cat-back,Rancho 5000's,
TT + Shackles, 200 Amp Alternator,
Autometer Gauges, 150 Watt Lights
Detroit Locker in Rear
Billy177 is offline   Reply With Quote
Old 02-16-2004, 10:12 PM   #6
Vozar
Was Fordbeast98
Vozar's Avatar
Vehicle Specs
(Original Poster)
Ok i found out what the problem was. As you know your abs sensor connects to you hub. Turns out my wheel bearings were going bad. I replaced the the hub assemblies this weekend and the abs light went out. Voila! i fixed two problems at once.
-Matt-
__________________
Old 03-04-2004, 07:44 AM   #7
SmokeGrinder
Uber Of All Possible Doom
SmokeGrinder's Avatar
97 explorer 4X4
Vehicle Specs
I have this same problem...
I have just put my new rotors and pads on too. the problem went away for a while but now its back again.
the abs cuts in when you are going at slow speeds and hit the brake...
I think im gonna try cleaning the sensor before i do anything.
SmokeGrinder is offline   Reply With Quote
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
