| Explorer - Ranger Shocks, Suspensions, Lift Kits Ford Explorer and Ranger chassis related posts. Get help choosing the right shock absorber and aftermarket suspension for your Explorer or Ranger based vehicle. |
Thread Tools |
#1 |
Wannabe Elite Explorer
Eau Claire,WI
2000 explorer 5.0
5.5" lift with f150 spacers, aal, and SOA
Hey everyone. I am getting a 5.5" lift for the front end of my truck from another member here. It includes 5.5" lift coils, droped axle pivot brackets, extended radius arms, and extended brake lines. Now for the back, I just got a set of pro comp double add a leafs in the mail today which are supposed to give me 2-3", and I have a set of shackles that should give me 1.5-2". So for a total of 3.5-5" in the back. Is this gonna be really noticeable with 5.5" in front, and 3.5-5" in the back? I am contemplating doing a SOA in the rear which would give me about 5.5", and then just leaving the aal in, and taking out the shackles, then adding F150 coil spacers up front to help even things out. Do you think this would look ok? F150 spacers give about 1.5" right? so that would give a total of 7" in the front, and then the rear would have 5.5" of soa, and 2-3" of aal's, for a total of 7.5-8.5 in the rear. What do you all think of this setup?
Thanks, Andy __________________ 2000 explorer 5.0, manual BW4406 swapped, Cold air intake,true dual exhaust, billet grill, clear tails, sport trac white faced gauges, euro projector headlights with HID conversion, stainless brush guard, stainless nerf bars,TT and shackles with 31" Goodyear wrangler duratracs on 15x8 Dick cepek dc-2 rims. |
#2 |
Moderator Emeritus
Mountain Home AFB, ID
No more Exploder
Wow, you've got quite the contemplation. Any less lift in the rear will be very noticable. With the 5.5" front, all you will need is a SOA in the rear and maybe an AAL after the springs settle. That's what I was running for a long time. The double aal will ride very stiff and not flex well. What size tire are you wanting to run? Sway bar quick disconnects are a great addition to the front. Don't worry about running your rear sway bar. I never noticed a difference once it was removed. A set of selectable shocks are worth their weight in gold. Always check your drivelines after the lift; most likely needing to be extended.
__________________ US Air Force Mission Director '96 Ford Bronco (daily driver) '67 Land Cruiser trail rig project "My Give a Damn is Busted!" |
#3 |
Eau Claire,WI
2000 explorer 5.0
I am planning to run 32's or 33's, only because I have 3.27 gears, and its gonna be slow enough as it is. I am not planning on using a front or rear swaybar.
#4 |
Moderator Emeritus
No more Exploder
The 5.5" lift is plenty for 33s. Anymore lift and I don't think it would look good. With the Rancho RS9000 shocks I didn't need the front sway bar but with anything else on the street you really might want one.
#5 |
Ogden, UT
1993 Sploder
I ran shackles and a single AAL in the rear for a while with 3" up front. Looked about right. I hated the stiff rear though. The best thing I ever did was a SOA and add the spacer. I would ditch the AAL and Shackles and do a SOA. Flexes better, rides better, better departure angle. Besides- why would you go higher than 5.5? I am going to run 35s with my 4.5". Mine is too tipsy as it sits with 33s. just my $.02
__________________ SOLD 93 Sploder- HP Dana 44 Front, 37" MTRs, 4.56s, 1354 doubler, ARB, Detroit, Winch, Kirby Built Armor, etc... 05 Jeep Rubicon Unlimited LJ 4" Lift, 33s, 94 F150 |
#6 |
Denver, CO
'92 Sport and AMG 300CE
Wow, I have a double here. I'm currently doing that with the skyjacker lift 6" with the spacers. and yeah i have the shackles and AAL too (skyjacker) and on top of that have a 2" or 3" body lift. now I wanna keep my AAL because my springs were sagging off towards the left and the AAL fixed the problem well. Haven't started the SOA yet but will as soon as it starts to get a little warmer here. I'm also in the middle of having my friend regear my gears for me, cause let me tell u man 3.27's are cool on the highway only but hills climbing, accelerating, just daily driver stuff sucks. I have 32's on it now. So please take this warning if your going to do all of this upgrading with your tires-- please regear your EX, Until I knew that gearing was my problem I went through 3 sets of clutches in one year. I had to rev my engine over 2500 RPM just to get it rolling from start. So please beware.....
__________________ 305/40r22 Nittos, KMC Rims, K&N, Granatelli MAF, BBK TB, Borla muffler & headers, Magnaflow Cat, 4" lift (Assorted Parts), 2 15" Eclipse Subs+Amps, 4.56 gear ratios, SCT 5 Program Chip, Warn Hubs, Paxton Supercharger SN2000, Port & Polished 95TM Heads+Lower Intake, 422 Cam, 30lbs Injectors, Snow Water Methanol Kit, Ready to Race!!! IF YOU GOTTA BE A MONKEY BE A GORILLA |
| Thread Tools | |
