'99 XLS Overheating Sometimes | Ford Explorer Forums
geekdrew
Reynoldsburg, OH
'99 XLS
Last night, I drove home from work, and all was well... drive out to see a client, then to dinner, no problem. Ate for about 30 minutes, then got back in the truck. Got on the freeway... about 4 miles later, the temperature guage is reading higher than normal.
I don't recall my temp guage having any markings on it besides 'C' at the lower end and 'H' at the upper end. Most of the time when I'm driving it, the guage stays at maybe 15-20% up the scale from Cold... not indicating it's very hot. Last night on the freeway it was about 50%. Since I didn't see any markings indicating what the normal temp should be, I assume it's not a good thing that it's running that much hotter than normal.
I eased off the gas and just drove pretty steady, so I didn't have to speed up/down much... I was on my way to a friend's house about 30 miles away. About 1/2 of the way there I felt a little chilly... so I turned on the heater. I had the temp knob at about 2 O'Clock, with the fan being on the 2nd position, and the windshield defroster was selected.
Lo and behold, I look down a minute or so later, and I'm watching the temp guage creep down. When the needle hit the stop boundary just below 'C', I turned the heater off, to see what would happen. Within a minute or so the temperature had jumped back up to about half-way up the guage (50% of it... whatever that temp would actually be).
By that time I was rather warm from the heat, since I had *just* shut it off. However... if it supposedly kept the engine cooler... I drove the remainder of the way with the heater on and my windows open.
Got to Jason's house at about 7:00 PM. We were in a crisis situation with some other things, so I didn't get back to the Explorer till 3:30 AM. I noticed that the white reservoir for the coolant is completely empty. I take the cap off of the radiator... I can't see any coolant at all. So I put the cap back on, shut the hood, and slept at Jason's.
Skip to this morning. I refilled the radiator and the white reservoir. I then drove 20 miles to my biological parents house, and the temperature stayed fairly low the entire way... lower than it was last night, but still higher than normal.
Three or four hours later I leave for my house... a couple of miles away, I notice that the temperature guage is back up to last night's high. I turn on the heater and put down the windows. The temperature drops. I had to stop for fuel, so I checked the white reservoir and it still had the same amount in it that we put in it this morning. I didn't want to take the radiator cap off because I had been driving and I'm not familiar with how much pressure it may have been under.
I drove the remainder of the way with the heater on and the windows down. I tried turning the heater off when I was on a stretch of road that allowed me to stay at relatively low RPMs, but the temp still climbed to the same high level. I just got home a short while ago, so I figured it couldn't hurt to post here before I take the truck to some place to have them look at it (as I am not in the least bit mechanically inclined (other than with computers ;))).
Any thoughts? BTW, the top radiator hose IS getting hot.
<edit>
Also note that a similar problem happened about 3 months ago... nearly the same thing, exactly. It seemed as though the coolant was just disappearing. I refilled the white tank and the radiator a couple of times, because it kept drinking the coolant. And then the problem stopped as suddenly as it started... the coolant remained there, and the temperature guage reflected that it was OK.
Check to see if you coolant is low & change the thermostat..
Originally posted by geekdrew
...So I put the cap back on, shut the hood, and slept at Jason's.
Skip to this morning...
Is there something that happened inbetween that we need to know about?
J/K ;)
I say change the thermostat also.
so its not leaking?
Any funny smells or smoke from the exhaust? I sure hope it's not eating the coolant.
Hopefully it's not eating it. A pressure test should rule that out. If so, head gaskets and maybe a milling of the head surfaces.
The X has a short lived thermostat and also check the housing bolts for tightness since if they are like mine, they loosened up to about hand tight on their own and I don't know why it wasn't leaking.
The sending unit is going.
Check your radiator making sure the dead grasshoppers, grass, or mud haven't clogged up the heat transfer fins.
Running your heater is like increasing the size of your radiator, so that makes sense your temp goes down.
That's the best I can do//good luck
Well I haven't seen any smoke from the exhaust... I have been smelling something a little funny... but I'm not sure if it's from the engine or not. The only thing I can compare the smell to is what one of the district transit buses smells like... and it has a diesel engine.
I'm afraid there's probably something wrong with the engine. I'm gonna start by buying a thermostat... and Jason and I will probably change it together. Neither of us know THAT much about it... but he knows more about them than I do.
So... I don't know which thermostat to buy. I went to NAPAonline... should i buy part THM 285 or THM 533090? My engine is a V6, vin X.
Re: Re: '99 XLS Overheating Sometimes
J/K ;)
I avoided saying anything for a little while... but I decided I couldn't resist. You might not be asking that if you knew me... the right sidebar on http://geeklog.geekdrew.net will explain what i'm talking about.
OK... so I had a mechanic look at it today. He ran it for over an hour and a half (idle), and it didn't overheat. He said that he didn't have time to drive it around, but he said he has no idea what the problem could be, since it didn't overheat that time.
I'm going to see if a friend will be able to replace the thermostat this coming weekend... any other advice or recommendations?
