mattadams
Moderator Emeritus
- September 17, 1999
- Longmont, CO
- 2017 Explorer Sport
ok heres the situation. Noticed off and on since Moab that the windshield wiper fluid wasn't coming out, then it would come back on for a while, then stop. Then it stopped for good, wouldn't get any out, ever. Figured maybe it was a bad pump so I replaced the pwoer steering pump for about $25 from Ford, swapped it out myself in about 15 minutes, no sweat. Power steering pump was wokring and fluid was coming out good and in nice streams for quite a while. Didn't run it for a while, then today went to go squirt some otu and low and behold, its not spitting anymore! So I blow out the lines (disconnect where it brances to the seperate squirters) blow air in, it goes fine all the way back to the reservoir, then I squirt and fluid comes out, I figure ok maybe theres some crap trapped in the lines but its working again. Try it 5 minutes later just for testing and no squirt!!! Any ideas? the fuse seems fine, power steering pump looked fine going in and worked well for a while. The tubes didn't seem kinked or pinched in any obvious locations.
