spring over questions | Ford Explorer Forums
93SPORTIOWA
SIOUX CITY IOWA
93 SPORT
ok anyone have any opinions on the spring over lift how much lift does this give? how hard is the mod? where do the shocks mount? i like the clean look of this mod. what do i do in the front to even out the lift? what is the ride quality like? this is a daily driver. how about shock length and articulation? over all is this a good lift and how is it done?
thank you all in advance
brian
hmmmm some of you have this lift
i know some of you have this lift please help a fellow explorer brother out
SOA is quite easy.
I picked up a set of spring perches from my local speed shop for under $20 and you can use the stock length shocks. I have the lowers mounted to the sway bar bracket for now.
Ride quality remains the same. I used SuperLift 4" lift up front...
how much
how much is the front 4inch super lift?
Depends. With extended RAs ~$600.
