Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Under the Hood
Notices
Under the Hood Ford Explorer and Ranger, Engine, troubleshooting, modifications, performance and accessories.
91 4x4 sprayed out all the ATF
Reply
Thread Tools
Old 12-04-2000, 11:15 PM   #1
mahieber
League City, TX
'92 XLT 4x4
Vehicle Specs
(Original Poster)
Question
I was 298 miles from home, 2 miles from my deer lease, when my automatic tranny stopped engaging, and I had ATF dripping from the bottom of my truck when I stopped. It seemed that it must have started as a small leak somewhere on the right above the exhaust because there was black sooty oil all over my hatchback. It drained pretty fast at the last because I left a pretty good trail as I coasted to a stop. It is still down in S. Texas, sooned to be towed up. Any ideas where to start looking? The fluid seemed to be dripping towards the front of the tranny or even next to the motor. Didn't see any problems with the cooling lines.
p.s. If you have 2 big enough hog traps you can stack them on top of each other and make your own cellular tower.
__________________
Michael
92 XLT 4 Dr 4x4 33x12.50s on Black Rock Crawlers, SmittyBuilt Tube Front w/W9000, 3" body lift, Lift Lips, 2 1/2 "Rancho suspension lift w/Warrior shackles.
mahieber is offline   Reply With Quote
Old 12-05-2000, 12:43 PM   #2
SteveVB
Gaithersburg, Maryland
SteveVB's Avatar
04 Rubicon w/stuff
Vehicle Specs
vac modulator
I would check the vacuum modulator and the vacuum hose that leads to it. It is up on the side of the trans, just above the pan rail, on the pass side right next to the exhaust. You need to remove a heat shield, and a bolt to get the valve out. Thats my best guess.
If its coming from the bell housing then could be the pump seals, or the convertor- lets hope its the modulator!!!
Good luck
__________________
Steve VB
04 Rubicon
SteveVB is offline   Reply With Quote
Old 12-05-2000, 10:18 PM   #3
Gofast
Moderator Emeritus
McKinney, TX
Gofast's Avatar
76 Bronco
Vehicle Specs
Thumbs down Death signs...
This is what happend to mine. The front seal blew. It pumped all the fluid out at the front of the tranny. Everything under the truck was covered in gunk.
I bet this happened at night and you couldn't see the cloud of smoke behind you as the fluid spryed on the hot exhaust.
Good Luck
__________________
Rob Robertson
The ghost of Explorers past!
Gofast is offline   Reply With Quote
Old 12-05-2000, 10:41 PM   #4
mahieber
League City, TX
'92 XLT 4x4
Vehicle Specs
(Original Poster)
Death Signs
Did it screw up your tranny? I am working out of state, and it finally got trailered back to Houston today. A friend of mine put ATF in it and was able to drive it around the parking lot with no apparent problems, but he could see it leaking from around the front seal area.
__________________
Michael
Old 12-05-2000, 10:52 PM   #5
Gofast
Moderator Emeritus
McKinney, TX
Gofast's Avatar
76 Bronco
Vehicle Specs
Post Maybe..
Mine blew out on the way to CCR2000 this year. I caught it in time thanks to Sinjin. I was blowing smoke intermittantly out the back. It would be real heavy then clear up.
I put a new seal in it and drove it about another week or two. The seal blew again, at night. I did not see it go this time and the tranny burned up.
The leak was very noticable from the front area. It would leak very badly then it would stop for a bit then leak again.
I read some more about this on one of the ranger boards listed under 302 conversion's. They said once the seal went you needed to rebuild, the shaft may be to worn for the seal to work good now. Seems this may be a common problem for the A4LD tranny.
Good luck
__________________
Rob Robertson
Old 12-05-2000, 11:27 PM   #6
Houston at NCSU
Raleigh, NC
94' XLT 2WD
Vehicle Specs
DO NOT TAKE IT TO TRANSPRO TRANSMISSIONS ON NASA ONE NEAR HIGHWAY THREE UNDER ANY CIRCUMSTANCES. AS A MATTER OF FACT, I WOULD NOT RECOMMEND ANY TRANSMISSION SHOPS ON NASA ONE. But i dunno where you live in houston, just avoid that area.
__________________
'94 XLT w/ Rod Holders & Fog lights, just installed K&N filter
finally drilled the airbox
Houston at NCSU is offline   Reply With Quote
Old 12-06-2000, 11:09 AM   #7
AgExplorer
Houston, TX
'03 Sport Trac XLS
Vehicle Specs
If you're looking for a tranny shop in Houston, I highly recommend A+ Transmissions on Dairy Ashford between I-10 and Memorial. (281) 293-7090 and ask for Dennis.
AgExplorer is offline   Reply With Quote
Old 12-06-2000, 11:52 AM   #8
mahieber
League City, TX
'92 XLT 4x4
Vehicle Specs
(Original Poster)
hehehe Thanks for the warning about Transpro. I do live right there in League City. I am taking it to Snider's on 518. They have done work for me before. A little pricey, but didn't have any troubles with them.
__________________
Michael
Old 12-16-2000, 08:01 PM   #9
mahieber
League City, TX
'92 XLT 4x4
Vehicle Specs
(Original Poster)
Unhappy Truck is fixed
Most of the front of the transmission including the pump had turned blue from the heat. They disconnected the coolant lines at the radiator and could not get anything but black gunk oozing out of the radiator with 120 psi of air. Had to rebuild the tranny and replace the radiator (in lieu of just using the auxiliary cooler...too hot in Texas). So for those of you that perform the self-help procedure of flushing the tranny, make sure you flush the coolant tanks (radiator and auxiliary) also.
__________________
Michael
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
91 XLT 4x4, grinding in front end bus357 Elite Explorer 911! 6 12-01-2003 12:02 AM
Finally 91 2dr EB 4x4 Steve A Explorer Registry 4 08-15-2003 11:16 PM
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
