Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Offroad Tech Forums > Offroad Explorer - Ranger Projects > Explorer - Ranger Shocks, Suspensions, Lift Kits
Notices
Explorer - Ranger Shocks, Suspensions, Lift Kits Ford Explorer and Ranger chassis related posts. Get help choosing the right shock absorber and aftermarket suspension for your Explorer or Ranger based vehicle.
DANGER:Add-a-Leaf Owners Read This Now!
Reply
Thread Tools
Old 04-13-2001, 07:43 PM   #1
GJarrett
Moderator Emeritus
Chief GPS'um and Still Lost Native Texan
GJarrett's Avatar
'99 EB 4x4
Vehicle Specs
(Original Poster)
Exclamation
Check your center bolts (the one with the round head in the middle of the leaf pack that holds it together and lines the springs up into the alignment holes on the bottom of the axle). Do it Right Now!
I took the day off and started my pre-Moab inspection and nearly had a heart attack when I noticed something.
My ProComp Add-a-Leaf kit came with wimpy looking 5/16" center bolts to hold the leaf pack together. I thought they looked too thin but shrugged it off figuring ProComp knew what they were doing and the center bolts they supplied were strong enough to do the job.
Guess what: both of mine were sheared off! I do not know how long I have been driving with them that way but visions of what happened when Ray Hutchinson sheared one of his off at Moab last year left me in a sweat. What if my axle decided to shift and go south like his did, while I was doing 65mph in Dallas rushhour traffic on a freeway?
I spent today acquiring repacement 3/8" bolts from an offroad shop and replacing the center bolts. Ford does not stock them; they only come with a complete leafspring kit. You'll have to find them elswhere.
Hope this saves someone's a$$. Take care guys.
__________________
Ol' Krusty
"Nerves of Steel; Brain of Chipmunk"
Gerald's Truck
The best things in life........ aren't things.
God's aim looks like He's missing the mark because we're too nearsighted to see what He is aiming at.
GJarrett is offline   Reply With Quote
Old 04-13-2001, 07:48 PM   #2
BoatsRcool
Greenville SC (Home) Clemson SC (School)
GMC Yukon 4x4
Vehicle Specs
Thanks man, I just put my add a leaf in last week, and I will check up on the bolts every once and awhile.
BoatsRcool is offline   Reply With Quote
Old 04-13-2001, 09:01 PM   #3
NoBoundaries
Moderator
ECX Member
Ellicott City, Maryland
NoBoundaries's Avatar
1996 XLT
Vehicle Specs
Hey Gerald,
Have you sent a letter to Pro Comp regarding this and asking for some sort of an explaination? Maybe they might come up with a free replacement or at least help other consumers aware of the potential problem.
NoBoundaries is offline   Reply With Quote
Old 04-14-2001, 03:24 PM   #4
Tito_146
Coral Springs, FL
2002 Eddie Bauer
Vehicle Specs
Do you know where do i get the add-a-lift and for how much? Do you guys think I should go for a shakle instead? I have a TT on a '96 4x4.
Thanks
__________________
Tito, FL
XLT '96 4x4 (Sold)
Eddie Bauer '02 (Sold)
Eddie Bauer '08
Tito_146 is offline   Reply With Quote
Old 04-14-2001, 04:46 PM   #5
BoatsRcool
GMC Yukon 4x4
Vehicle Specs
Warrior shackles stick out, add a leaf is just a leaf, I think warrior shackles are easier to put on, but if you have a 2door (sport) do the shackles.
Old 04-21-2001, 06:31 AM   #6
Alto
Home-Lake Mills, Wisconsin / Live-Saudi Arabia
Alto's Avatar
1995 4DR XLT 4X4
Vehicle Specs
Angry Noticed Myself!
I noticed it myself! I felt they were a bit to thin in diameter.
I got high quality Nuts & Bolts. I got larger bolts Ground the heads round to fit hole on top. The bottom side I also ground off the corners a bit.
I figured since I'm doing the work I know they are tight Used Metwrench to tighten the ground nuts. I noticed that everyone has problems getting the Centering bolts out anyhow. If I need to remove them I KNOW that I'll have to cut them off. But they are now larger.
Question? When I bought mine from Summit. At $26.00 (Explorer Pro Comp) that was for one set! Correct? At the time I was not sure I ordered Quantity 2. Now do I have 2 sets or 1 set. One box 2 leafs I believe 4 nuts & bolts. I have two boxes.
The reason I'm asking it I really didn't get any lift. If I installed correct 1 box. Then My present springs are just worn out. Meaning I installed correct and the lift just leveled me out. Now if I'm correct I'll just order the OME 2" entire spring pack.
Confused Yet! Welcome to my World! Try not to stay long. Maybe a picture will help! I'm good with Pictures.
__________________
- Land of Sun & Sand- "TT", OME 2" Lift w/ Shocks, 3" Body Lift, Rhino Guards,
275 / 80 R15 Sumitomo Shaheens, 15"x10" Rims, Custom Rear Bumper Guard, Hella Lights, Flowmaster, Conferr Rack...
pist. . . I See Voices ! Is That Wrong?
Alto is offline   Reply With Quote
Old 04-22-2001, 06:12 PM   #7
J. Kennedy
Acton, Mass
1995 XLT
Vehicle Specs
Hey Alto
I know what you mean re: Add a Leafs. If your original leafs are seriously sagging, the lighter leafs won't give you any lift at all. My rear was down about 1.5", and the leafs brought it up 2" initially, but then settled to stock height.
If you want actual lift, your are going to need at least the mid grade leafs.
Or, Ford could install leaf springs that had more rebound than Jell - O.
__________________
1995 XLT with: DRYER HOSE!, Add-a-Leafs, Edelbrock shocks, Powerstop drilled discs w/ 911 pads, Energy Susp urethane end link & sway bushings, Electric fan. oh, and FORD SUCKS!
J. Kennedy is offline   Reply With Quote
Old 04-24-2001, 11:43 PM   #8
2001ExpSport
Chicago, Il
2001ExpSport's Avatar
2001 Sport
Vehicle Specs
Lightbulb
My guess as to the reason they sheared was because of improper installation. My leafs came with the same size bolt as stock. Also over tightening the bolt with weaken it and cause it to snap. They should only be torqued to a max of 80lbs.
2001ExpSport is offline   Reply With Quote
Old 04-27-2001, 01:39 PM   #9
NoBoundaries
Moderator
ECX Member
1996 XLT
Vehicle Specs
I gave Explorer Pro Comp a call today and they are sending some 3/8" center bolts out to me. I was kind of concerned when I was putting the bolts on that it might be a problem. I figured that it wasn't rocket science and that Explorer Pro Comp knew what they were doing.
Old 04-27-2001, 01:50 PM   #10
HIX
Denver, Colorado
94 Mazda 4.0 4x4 SuperCab
Vehicle Specs
One thing ya'all Should think about...
The Center pin is just to hold the leafs centered on the axle. If you are using the pin to clamp down the spring pack or if you do not clamp down the u-bolts tight enough you will break the pins even if you get the "good" ones. I broke three on my X before I really cranked down the u-bolts...never happened again after that.
__________________
HIX
When that happens you need two things and two things quick: A pair of ice tongs and a friend that can keep a secret
HIX is offline   Reply With Quote
Old 03-15-2003, 12:02 PM   #11
sk1er17
My "Jeep Thing" itches...
Jackson,NJ
sk1er17's Avatar
'98 Sport
Vehicle Specs
I ordered the DOUBLE AAL kit from pro-comp. The bolts they came with are 3/8". Is that the size bolt stock on the leaf packs? (my brother has the single leaf kit and i looked at his bolts and noticed they are smaller....)
Also, why are there two nuts for 1 bolt? Do i use both of them when i install these? (2 bolts are goldish in color and two are black)
__________________
My Elite Registry.. Check it out
Cardomain Site
Explorers Gone... Went to a Silverado with 8" lift and 37s, then to a 2008 Sierra Denali with 3" lift and 33"s... Now, finally back in an off-road worthy rig...2007 Jeep Commander Hemi QDII (front & rear e-lockers).
Build Thread: Here
sk1er17 is offline   Reply With Quote
Old 04-10-2003, 07:00 PM   #12
Heath
Elite Moderator Intoxicator
Rigby, ID
Heath's Avatar
'01 XLT Slightly Modded
Vehicle Specs
Matt and I just installed mine... I ended up getting a bolt that was the same size as stock... We used a round headed bolt with the hex in the middle... then I had the AAL's drilled by a local leaf spring company to fit the bolt (since it has that tiny hole) and installed them... I think the drilling and nuts and bolts added almost $20 to the pricetag, but well worth it to do it right the first time and have the peace of mind knowing that its done right...
__________________
Rigby, ID
2001 Explorer V8 XLT with a mod or two
"Never fight an ugly guy, he has nothing to lose"
Mugshot Updated 8/6/10
To support the site and upgrade to an elite membership, Click Me!
Heath is offline   Reply With Quote
Old 04-10-2003, 07:18 PM   #13
fordtruckin
Atco, NJ
99 Sport
Vehicle Specs
where can i get instructions for installin the warrior shackles on my truck 99 explorer sport 2dr 4x4
fordtruckin is offline   Reply With Quote
Old 04-10-2003, 07:23 PM   #14
Joey P
On my 5th Explorer
Lakewood, CO
Joey P's Avatar
1999 Ford Explorer EB 5.0
Vehicle Specs
I just installed a pro comp aal and the kit came with 4 bolts. 2 bigger ones and 2 smaller ones. I used the bigger ones because they just looked better, also stronger for that type of thing. Has anyone else had 4 bolts come with theirs? I do not know what the other 2 bolts would be for, I just saved them for something else. Also the bolts I ended up using had a slot in the head.....like a flathead screwdriver slot. The other ones did not.....like the factory bolts. I am sure this does not matter though.
Edit: This was a 2 inch kit that I bought off of ebay from rdsi racing or something like that.
__________________
There are two types of people in this world:
1.Those who get lemons and make lemonade.
2.Those who get lemons and squirt the juice in their eyes.
Updated Mug shot 2/12/09
Joey P is offline   Reply With Quote
Old 04-10-2003, 07:23 PM   #15
410Fortune
ELITE BRONCO2ERER
Crawlorado
410Fortune's Avatar
B2 Mod
Vehicle Specs
I had Superlift add a leafs (both long and shirt) installed until recently. They came with the larger bolt, I actually had to drill the lift blocks to accomodate the bolt.
A good heads up there Gerald.........That is SCARY
Do you think Ray's bolts were the Pro Comp?
Nice job with the pre trip inspection, I was just reading about that in a 4x4 mag....Everyone should go prepared and do a THOUROUGH inspection of the truck before any road trip, especially towing or 4x4ing trips.......
__________________
96 Explorer daily driver build-1996 XLT 5.0L AWD to 4x4 conversion complete on 33's
88 BII 5.0L conversion - BII 5.0l drivetrain thread
My Bronco II - 1988 Bronco II 4x4 V8 on 35's - registry and updates
Wifes 07 FJ build - 2007 FJ cruiser locked and lifted
410Fortune is offline   Reply With Quote
Old 04-10-2003, 08:10 PM   #16
Jefe
Roll Over Posse Recruiter
Clarksville, TN
'00 XLT 4x4
Vehicle Specs
Since this was brought back to life:
Its all about tightening the U-bolts, and then retorqueing(sp?) them. Whenever you unbolt the u-bolts, you need to torque them down to 100 ft/lbs, and then torque them again the next day, and the next. . .until the you check them and they are already at 100 ft/lbs, and even then its not a bad idea to check them on occasion later.
I have been running the "wimpy" pin for over 2 years with no problems. The U-bolts should be holding the axle in place, not the pin.
A friend did an AAL on his rodeo. the pins with the kit were 3/8" and he sheared both of them because he torqued the U-bolts down and promptly forgot about them until I asked him why his rear tires were not centered in the wheel wells.
__________________
'00 Explorer XLT - Sold
'01 Focus SE
Jefe is offline   Reply With Quote
Old 04-11-2003, 08:40 AM   #17
GJarrett
Moderator Emeritus
GJarrett's Avatar
'99 EB 4x4
Vehicle Specs
(Original Poster)
Thanks HIX and Jefe for the info. As long as we learn how to do it right and safely, that's what it is all abou!
__________________
Ol' Krusty
Gerald's Truck
Old 04-11-2003, 11:15 AM   #18
Heath
Rigby, ID
Heath's Avatar
Vehicle Specs
I think I'll crawl under my truck and tighten them up again tonight... Just in case...
__________________
Rigby, ID
Old 04-11-2003, 11:25 AM   #19
MO_GUY
Farber, MO
MO_GUY's Avatar
2000 Explo Sport 4.0 SOHC
Vehicle Specs
I think this thread gets my vote to be a sticky! It's info that needs to be seen
__________________
I have a lot of things planned for the X in the next few months. Hopefully it'll all turn out the way I want!
If a tree falls down in the forest and no one is around to hear it.....who the hell cut it down?
My Cardomain Site Last Updated: 4-10-03
MO_GUY is offline   Reply With Quote
Old 06-05-2003, 10:50 AM   #20
reichhartkg
Canton, NY
99 XLT
Vehicle Specs
I've read in this thread that the Ubolts should be torqued to 80 and 100. Which is it?
Also, is there a torque spec on the center bolts?
__________________
Kevin Reichhart
Newest member of the rollover posse
reichhartkg is offline   Reply With Quote
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
