Usaully that seporator plate is an issue if the tranny is making a whisting noise in idle , all gears
EXCEPT N
There is a TSB on this and that is the fix. it really doesnt hurt anything to run it that way and shouldnt have caused
any surging?
98-5-14 MAR 98 Whistling/Hissing Noise From Transmission During Idle
ISSUE:
A "whistling" or "hissing" noise from the main control area may occur while idling in Drive and/or Reverse on some vehicles that have either a 4R44E or 5R55E transmission. This may be due to an improperly sized orifice hole in the main control separator plate.
ACTION:
Replace the separator plate with a revised separator plate. Refer to the following Service Procedure for details.
SERVICE PROCEDURE
1.Perform normal diagnosis by referring to the appropriate model/year Service or Workshop Manual.
2.Repair all Diagnostic Trouble Codes (DTCs) as listed.
3. Repair all transmission concerns as required.
4. Verify that the whistle/hiss noise still exists. If the condition still exists, install the revised Separator Plate (-7A00
onto the main control. Refer to the Service Manual for proper procedure. Refer to the following Application Chart for the correct separator plate.
NOTE:
IF A SYMPTOM OTHER THAN "WHISTLING/HISSING" REQUIRES REPLACING THE MAIN CONTROL, REFER TO THE MAIN CONTROL CHART WITH THE UPDATED PART NUMBERS FOR CORRECT APPLICATION.
