irtySanchez
- March 28, 2001
- Chicago
- 94 XLT
I have had a problem since I have owned the 94 Ex. The temp gauge always stays low, but when I turn the A/C on, it heats up. The gauge will read between the A and the L in normal. This only happens after about 10 or 15 minutes with the air on. It never happens with the A/C off. Otherwise, it runs fine. If I am on the freeway, I can have the A/C running and it will NOT overheat at all, no matter how long it has been.
Well, today it was about 90 degrees in Chicago (bear in mind that I was doing in-city, heavy stop and go traffic as usual), and I felt the need to run the A/C. As usual, I ran it for a while and the gauge went almost all the way up. So I turned off the A/C, and let it cool down. Then I turned on the A/C 10 minutes later again, and the gauge went back up. I get home, park the Ex, and hear a bubbling noise. I pop the hood and the overflow tank is rising its level quickly and the fluid is boiling! It was a fierce boil too! I give it a few hours to cool off, get back in it without the A/C, and the temp gauge is normal throughout the drive.
Here are the facts:
-It isn't the T-stat (I replaced it 2 months ago and it still didn't fix the problem).
There are no visible leaks, and I don't seem to be losing any fluid.
I have to drive it 400 miles this weekend and I don't want to have any problems. Any suggestions? Could I possibly have a bad antifreeze/ water mix?
Thanks!
Here are the facts:
Thanks!
