Thank you Rhett for the quick response, because my Explorer has the dual exhaust with the dual cats, one of them perfectly placed UNDER THE TRANSMISSION PAN, great planing from the engineers at Ford that designed the Explorer, I don't have to worry about anything hitting the pan, lol.
Just finished the project and was able to find a spot to the rear of where the filter sits closed to the bottom of the pan. This should make it a little easier next time I do a transmission filter and fluid change.
By the way on my Explore it was easier to let the front drive shaft hang down so I could slide the pan to the driver side, over the front drive shaft and then down from the side that's closest to the cat, coming down at a 45 degree.
On another note, thanks to Pax for suggesting using fishing line to tie and hold the gasket in place until you can get the bolts in. I had no fishing line so I used a clothesline rope and took some of the thinner strands and tie the gasket in place on the pan and was able to hold the gasket in place until I started to put the bolts in. The strands just pulled out very easily, no need for Vaseline, grease, silicon or anything else to hold the gasket in place.
Thank you Robert for the Aluminum foil suggestion to cover the exhaust pipes.
Hope this helps the next member that runs into this.
Thanks again to everybody who contributes to this forum.
