zems
- June 12, 2003
- Onawa, IA
- 1997 XLT
I have gotten some good advice from searching these forums but I haven't found a situation similiar to mine. I have a 1997 Explorer 4x4, 4.0 SOHC with the 4r55e transmission,145000 miles. The transmission has started to grind when you let off of the gas going 35mph or faster. I have noticed that the grind doesn't start until the engine rpms drop. When you let off of the gas the engine holds its rpms for a while then drops to 1000 rpms then the grind starts. If you bring the rpms back up to close to where they were, without accelerating, the grind goes away or shifting it into neutral will stop the grind noise. Also when you put it in reverse you get the same grinding noise until it goes into gear. The reverse thing only happens once in a while. Otherwise the transmission seems to shift fine through all gears and does not slip. There are no codes when I scan it. This noise started as a once in a while thing to all the time in a weeks time. I will be running a pressure test on it soon and I do have the ATSG manual. Does anyone think the valve body or its gaskets could cause the problem. A transmission shop said it was probably the overrun sprag, but I realize they are in the business of selling rebuilt transmissions. I can not afford the quoted rebuild ($2000) so I would have to do it myself. What do you guys think.
Sorry for the long post,
zems
zems
