jsickles33
- November 18, 2015
- Milltown, NJ
- 1996 Ford Explorer
I've read many posts on here with concerns to what I am experiencing with my wife's 96 V6 explorer, run the truck for about 20-30 mins and then park it, after 10-15 mins go to start and its a crank no start. Have replaced the coolant temp senor, fuel filter, and the fuel pressure regulator. I've believe the fuel rail is getting vapor/air build up. When issue arises I can release the pressure from the fuel rail and she will start right up. I have also tried to remove the gas cap first to see if pressure releases but nothing.
My thoughts at this point is maybe the return line is clogged, in turn allowing fuel to stay in the rail and become cooked by engine heat??
Anyone have any ideas to correct this? Thanks in advance for any help.
