hueycrew
- March 14, 2012
- 1999 4dr SOHC V6
I have a starting issue. Cranks fine but no start. Broke down after a quick stop at a grocery store. Checked all fuses, relays for fuel pump. Would not start with starting fluid. After I had the Explorer towed to the house this is what I've found.
Electrical - Fuses good, relays good. Fuel pump runs when key is turned on.
Inspected all fuel lines, vent lines. no leaks found.
Fuel filter replaced 1 year ago
Fuel Rail pressure test:
Key on 55 psi and let it sit for 30 minutes - no pressure loss.
Able to start, cycled key 5 times, held accelerator pedal to the floor. Engine started, ran rough at first. Operation smoothed out. Had to keep RPM at or above 1500 keep it running. Pressure reading at 2000 RPM was 65 psi.
When I let off on the pedal the engine stalled at about 1000 RPM. Sputtered and died.
Fuel pump is about 10 years old (replaced once).
No CEL and no codes stored.
Fuel, Air, Spark. I feel that I have these three as I was able to start the engine.
What am I missing?
Help would be greatly appreciated. This vehicle needs to last until I retire in a few years.
- Joe
What am I missing?
- Joe
