jared4885
- November 28, 2013
- Milwaukee, WI
- 95 and 2000 explorer
I have bought 5 explorers in the past year, two of which I still have. I have been able to solve many problems using this forum but now I'm stuck. I bought this 2000 explorer with a v6 and the tachometer isn't working, then the next day it works again. Now its not working again. It doesn't work at all. Stays on zero. The first place I want to start is to figure out if the gauge itself is bad or if its not getting signal. I read in a different thread that pin 15 (tan/yellow) wire is for the tach. My question is what readings should that pin be putting out around idle, 700 rpms or so? How many volts, amps, ohms, what should I be reading and how many with the engine running at idle? If I can confirm the pcm is sending the signal then I'll take my chances on replacing the cluster.
