Will817
- June 22, 2013
- Fort Worth, TX
- 2001 sport trac
Ok to start this off i work at a shop and work on various different cars. i have a 2001 explorer sport trac. noticed the rear right window wasnt working, took the door panel off and tested the motor, motor works fine when i put 12 volts to it. then I noticed that the 30 amp fuse in the engine bay was blown, and blows everytime you push the button to roll down the passenger rear window. I've tracked it down to the drivers door wiring loom, ive found three ground wires that dont go to anything. Can anyone tell me if it is suppossed to be like that, or is it correct like that.
Heres a picture of the drivers door
http://s206.photobucket.com/user/wil...tml?sort=3&o=0
