DeviousVert
- July 3, 2005
- Brooklyn, NY
Well, I wired in a 400 watt amp, and all the tests before giving the amp a full blown test worked just fine. Well, I measured all the wires, cut everything to length and hooked it all up. I went to turn the key and there was nothing. No power to anything. Looked under the hood and a 30 amp ignition fuse was blown. Well, drove the other car to the parts store, got another one, put it in, and the truck started up just fine, but before firing it up, I disconnected the amp wiring. Then I hooked the hot wire up along with the ground and checked for power using a test light and there was power, I left the remote disconnected. Turned the key and the truck started. Hooked the remote up to a fuse that is ignition-on-hot only. Went to start the truck and it was dead again, checked under the hood and a 50 amp ignition fuse was blown. What in the world would cause a remote wire to blow fuses that in most cases should have melted that little wire long before a 30 or 50 amp fuse should have blown????
