logan222
- November 2, 2012
- Nashville
- 2004 Explorer
Ok....neighbors kid truck. 2004 2wd Explorer 4.0l OHC V6 with maybe 95k. Need some advice.
Sudden hard misfire with code PO305. No compression at all on cylinder 5. Suspected broken intake rocker or valve spring.
Got intake and rocker cover off yesterday. Could see the rocker over to side. Spring obviously broken. No retainer or keepers on top of valve. I was amazed the valve had not dropped into the engine.
Looked some more today with the owner. Valve spring broken in half. Rocker appears ok. Found the valve retainer and the 2 keepers.
At first glance yesterday, it seemed valve was locked in guide (did not really try too hard...ran out of time) Today...maybe not. I can move the valve down using my thumb...I can pull valve back up with pliers.
Is it possible for the valve seal to be tight enough to make the valve 'hard' to move?
Looking down the cylinder head intake plenum..valve tulip looks ok.
Should I just swap a new valve spring in...run compression test and hope for the best?
