2004explorerguy
- May 22, 2015
- 2004 ford explorer xlt
Good Afternoon,
My explorer has 120K miles, was shifting like it should.
Normal highway driving, until after leaving a stop sign about a week ago.
I found it wouldn't go past 3rd gear, so pulled into a parking spot to look around for anything obvious.
Found out there was no reverse.
After a friend pushed me out of the spot, I could drive it home.
Before this...no warning signs...noises or clunks
o/d did come on, but no codes
I did a fluid and filter change, found nothing extra in the pan. The fluid was brown, no burnt smell. Magnet had fines covering it.
I pulled the solenoid block and went through checking it using the detailed walkthough on the site. The block passed all checks, including putting 12volts to the solenoids...they clicked.
I put it back together, fluid level is good.
Disconnected the battery for over 30 min before test drive
In drive it shifts up to 3rd and start revving up.
Manually, I can shift 1...2...3...drive before revving
Shifts into R, but no engagement felt..unlike D
I was going to adjust the bands...any other ideas?
Thanks in advance!
Thanks in advance!
