2006 Ford Explorer EB 4WD Emergency Brake Pedal not connected
rtt
Mississauga, Ontario
I pressed on the emergency brake pedal, heard snap and suspect cable separated from pedal.
Now there is no tension on the pedal and I have to pull the release and pull the pedal back into the disengaged position to engage the switch to turn out the emergency brake light.
What is the best form of action at this point?
How do I remove the brake pedal mechanism to view and assess the problem?
Thanks
I don't think I ever saw a post here about removing the ebrake pedal but I would remove the plastic trim and look up there how it is attached.
Start by checking if it's attached with rivets or bolts, and take it from there.
I would first look under the car to make sure it didn't break at some other point. Always try/look at the easiest things first.
Top Bottom
