Lildon21
- August 19, 2022
- McKenzie Bridge, OR
- 1996, Explorer
Hey everyone. I've tried to search other topics and haven't been able to figure this out for myself....Sorry. Lots of talk on bypassing the amplifier and whatnot.
Basically I bought a BOSS head unit and some connectors from rock auto. Hooked this one up. Bought this one just in case
Got it all hooked up today, head unit powered on, but no sound. I matched up all the wires that were labeled the same. Only one's that didn't have a mate were the amp turn-on (12V+), amplifier ground, and power antenna wires. So I put the amp turn-on (12V+) wire with the constant 12V and got sound. Speakers also worked when that was connected to the 12 Volt ignition/switched (12V+) wires. So, the speakers work when that 12V amp turn-on wire is connected to power.
The head unit also has an option in the setting to turn of the internal amplifier, and when I do that I lose sound. I'm wondering if this means the factory amp is even running or if I'm just completing the circuit for the speakers when I do this. And the speakers are working when connected like this...but from what I've read I'm not sure if I should be connecting things this way.
From what I've read on the forum and elsewhere it looks like I can bypass the amp via some jumpers under the passenger side kick plate, or via the amplifier behind the back quarter panel.
This is what the stuff I ordered and connected looks like, if it helps.
Is there a problem with connecting the amp turn-on to the 12 Volt ignition/switched (12V+) or to the constant 12V wire? Or do I need to use some speaker wire and bypass the amp? I'm guessing the former might kill my battery?
Sorry for not knowing what I'm doing here. Any help would be great! Thanks.
Head unit for reference:
