hawc
- July 10, 2010
- Gwinnett Area GA
- 98 Sport
Hi,
I've got a 98 Explorer Sport 4.0I OHV 5 speed with about 151K on the ticker. In the past few weeks it has started stumbling/bucking during acceleration at all throttle positions. It is worse as the engine is under more load such as going up hills. It's not throwing and codes and the idle is actually very good. I don't see any bad vacuum lines.
It has done this in the past but it was mild and infrequent and usually would go away on its own on the same trip. Now it's persistent and is at the point of being too annoying to drive.
I replaced the plugs, wires, and coil back at 141,000 miles hoping to get rid of the occasional stumbling. It still did the intermittent stumbling as before but it wasn't bad enough to be a concern. So I'm hesitant to suspect an issue there. The wires are NGK and the plugs are NGK fine wire platinums. The coil is an oem motorcraft.
I replaced the fuel pump and filter at 129,000 miles. Cold starts and hot starts are excellent. I don't have a fuel pressure gauge to check the fuel pressure.
In the past few days, I pulled and carefully cleaned the MAF sensor. No change. I also took a quick test drive with the MAF disconnected just see if the hesitation was slightly better. No change.
Also, I don't think this is related to the current issue but in colder weather (50's or lower) over the past few years it does throw a p0171 and p0174. It only does it when the engine is cold. If I clear the codes once the engine is warm the codes never come back on the same drive. I always suspected the upper intake gasket but never messed with it. Again, I'm not getting any codes right now.
Anyone got any ideas as to where to start? Anyone with a similar issue that was resolved?
Thanks
Thanks
