JohnH55
- January 11, 2020
- Lawrence, Kansas
- 2001 Explorer Sport 4x4
My explorer is an 2001 sport 4x4 256000 miles, and I rebuilt the AC systems. New compressor, condenser, accumulator, orifice tube, oring. The only old parts is the evaporator core, the lines and the low and high side pressure sensors. I flushed all the lines and evaporator core, then pulled vacuum and refilled the system, with 9oz pag46 and 30oz refrigerant, as per Ford spec. The low side at ~87 degrees, was 50 psi, the high side was 47 psi, the air got much colder on the highway, than at idle. I can't figure what is wrong, the only thing that comes to mind is that the high pressure shutoff switch, my be causing a problem. What is everyone else's opinion?
Thanks,
John
Thanks,
John
