ASC Sunroof blinking light means it needs resetting
From the nice folks at The Sunroof Doctor:
The sunroof control module may need to be re-calibrated. Push and hold the
Vent button for 20 seconds then test operation. If that does not fix the
operation, push and hold the Open switch for 20 seconds after the sunroof
reaches the full open position. Then test operation.
Some models have a track sensor on the LH side of the track. It is
attached to the bottom of the track with adhesive tape. If the sensor
falls down, the sunroof will not stop in the closed position. It will move
from vent to full open position or from open to vent. With the sunroof
glass open, look in the track on the drivers side. The track sensor is
approx 1/2" square plastic flush with the track. The hole will be in the
track when the sensor has fallen down.
The sunroof is powered by 2 hot wires.
Red Wire = Constant Power (Power with ignition on or off)
Orange Wire = Ignition Hot Only (No power when ignition is turned off)
You should see these 2 wires where the installer attached them to the fuse
box. Verify both wires are correctly connected. Both wires also have
in-line fuses. Make sure both fuses are good.
If the sunroof is getting correct power and the track sensor is in place,
you most likely need a replacement control module. These range in price
from $91.00-$165.00. They are located at the rear of the sunroof, above
the headliner.
ASC / Inalfa company is now known as Signature Auto.
For more assistance, visit an ASC/Signature sunroof service center:
http://www.signature-autoproducts.us/?option=com_findinstaller
Customer Service
The Sunroof Doctor
www.sunroofdoctor.com
