bartgillam
- February 19, 2012
- north augusta south carolina
- 1997 mercury mountaineer
I have a 1986 ford bronco II 4x4 that dies after about 30 minutes of driving/idling. It will start back up once it cools down. It does not appear to be getting fire once it dies. I have replaced cap and rotor, ECM on distributor, fuel pump relay. Anything else i could replace? I might try the coil as someone said it could possibly have a crack in it and be grounding out when it heats up but its mounted to plastic on the driver wheel well so i dont see how that makes sense. I have a second vehicle already but i would like to fix this one because it gets better gas mileage then the 97 merc mountaineer v8. Any suggestions would be appreciated.
