basically, the rubbing with wider/bigger tires is in the front, correct? i've read that it rubs either on the front sway bar, or the a-arm in the front.
So -- for my 18x9, would this be feasible:
255/55/18 (29.0" diameter) tires in front (no rub at all in front)
285/50/18 (29.2" diameter) tires in the rear
the rear will be fine - no rub. all i need to do is tie the brake line, is this correct?
i figure the diameter sizes are very small, so they can be negligible...
will this setup work? has anyone tried it?
any comments, thoughts, suggestions VERY welcome ..
thanks!
thanks!
