janderson4010
Moderator Emeritus
- August 15, 2009
- third boxcar, midnight train
- 86 BII
I promise i searched thoroughly before posting this question. so I'm gathering pieces to swap the m5od into my 86 BII which i believe has the fm146, my question is on the clutch, I'm going with the ex flywheel and clutch set, but what slave and master should i use? I'm hoping i can use the BII setup bk it is already in the vehicle. Will a BII slave and master run the m5od clutch set? btw i accidentally ruined the ex line between master and slave getting it out, nicked it with the sawzall getting the driver side exhaust out. it was dang rusty and i didnt want to fight it. any info would be awesome bk im on a limited time frame once i start the swap, i gotta dd this hotrod, thanks guys
