steadyhand
- May 5, 2010
- Missouri
- 99 Mercury Mountaineer
Ok I got my new radiator put on my 99 Mountaineer 5.0. I filled the radiator with coolant and filled the plastic resevoir to the correct level, but for some reason the small hose that connects to the radiator near the cap keeps leaking coolant.
The coolant inside the radiator is being forced up into the hose and starts leaking. Should I put a clamp on this hose to stop the leaking and not worry about it?
I figured it was air forcing the coolant up into that hose, but for some reason it doesn't seem to quit even though I would think all the air should be out of the system by now.
The reason I'm asking is because it never leaked coolant like that before. The truck runs fine. I let it warm up to operating temp and took it for a drive. It never got hot and I did see the temp gauge adjusting properly. It rose steadily until the thermostat opened and then it leveled out.
Is there anything I need to be concerned about or am I overly paranoid?
