88cougar
- September 29, 2007
- Edmonton
- 99 Limited AWD 5.0
Please bear with me. This may be long winded.
I am trying to solve a driveability issue on a 99 Explorer Limited AWD. Mileage is 120,000 and the only mod is a MAC intake. I suspect the MAF is shot but I wanted confirmation before I shell out $200.00 for a reman. one. I have tried cleaning it with no success (have cleaned it successfully in the past). The truck runs fine until it goes into closed loop at which point power drops off idle is rough and detonation occurs. I borrowed a scan tool to check for codes but there are none. I did a live data stream and here are the results:
Reading was done with Mac Tools ET-97 after a 15 minute drive and while idling in park.
RPM 725
Engine Temp 189 F
IAT 102 F
Timing 18 deg
MAF 0.63 lb/m
TPos 18%
Load 34.5%
STFT B1 -1.57 to 3.11
LTFT B1 4.67%
STFT B2 -1.57 to 3.11
LTFT B2 7.02%
O2 B1 S1 0.08 to 0.7 V
O2 B1 S2 0.08 to 0.2 V
O2 B1 STF -2.0% to 2.0%
O2 B2 S1 0.08 to 0.77 V
O2 B2 S2 0.08 to 0.77 V
O2 B2 STF -2.0% to 2.0%
I also had a notice EVAP SYST NOT COMPLETE.
I'm new to all of this and have no idea what I am looking at. Could someone please explain what these numbers mean? Also is 34% load and 18% throttle at idle high or is that normal.
Thank-you for your patience and replies.
RPM 725
Engine Temp 189 F
IAT 102 F
Timing 18 deg
MAF 0.63 lb/m
TPos 18%
Load 34.5%
LTFT B1 4.67%
LTFT B2 7.02%
