cgexploder
- November 19, 2011
- 1992 Explorer
So, recently the CEL came on in my '92 EB explorer. So I went through the procedure described in the haynes repair manual. First I just hooked up the test pin and read the codes off the CEL. The results were 22 / 22/ 1 / 22 / 66 / 22 / 66. If MrShorty is reading this, yes I know I should be getting 3 digit codes but I am not. I'm not misreading this I have done it several times. I even hooked up the old voltmeter and tried it again to see if I got a different result with that method and I didn't. So can anybody tell me what this means. I read in the manual that 22 is "Manifold Absolute/Baro Pressure Sensor out of range (low)" unfortunately as far as I have been able to determine my car does not have a MAP. Has anybody else had a similar problem. Any help is appreciated, but please don't tell me to search the forum unless you have a specific thread, because I have been haunting this forum for a week and have yet to find anybody that had this problem or found a solution to it.
cgexploder
cgexploder
