I had a small water leak coming in at the top of the driver's side rear quarter glass. (fixed glass in the cargo area) I was able to stop it by tightening the nuts on the back of the glass frame a bit. Here are my questions:
How tight should those nuts be? I just tightened them until they were firm, but I don't want to have the glass crack over time, or shatter at the first bump in the road.
If the leak comes back, what materials would I need to remove the glass and re-seal it? I assume the outside trim is not re-usable, based on the way it is attached.
Thanks.
Thanks.
