Peter Westling
- December 4, 2003
- Rosersberg, Sweden
- '93 XLT
One thing that has bothered me for long is my heater system. I am constantly changing the temp on the selector. Either it is too hot or too cold. Seems to be nearly impossible to find a place on the selector that is perfect.. My normal setting on a daily drive would be Panel/Floor. The problem is that floor is much colder than panel. Do I then add some more heat it will give the floor normal heat but the panel is like a flame thrower... Hope u get the idea here...
This is a non-AC.
I took a look at the airflow schema... Is this a probably theory of what is happening or is it something else, has anybody else this problem? I did a search but did not find any similar threads..
Assume I want PNL/FLR setting on the selecter and a mid temped air, just between the red and the blue..
1. Outside air gets in, 1st door is in pos A
2. Since I want mid temp this door is in mid, half of the air to the core, rest proceeds further.
3. Looking at schema I would say that most of the hot air goes to the panel and following the stream the cold air proceeds to the floor. (4)
Can one solution be that putting the selector in the rightmost selection and mechanically route (2nd door) all air through the heater core and control the core's heat electrically?
[Edit: I see that the heater core probably cannot be electrically controlled since it uses the heater hoses.. ]
This is a non-AC.
