welderman
- December 10, 2014
- 2010 explorer
Hey guys....need some help with a problem with the heat vents on a 2010 Explorer XLT. I'm sure there are several of you out there that have had the same issues.
If the selector dial is put on floor/defrost than most of the hot air blows on passenger side of console floor vents. Gets worse if you adjust the temperature selector dial all the way to the hottest position. You can actually hear the ducting door move inside the console and then almost all of the hot air blows on the passenger side vents.
If I put the selector dial on just floor vents it seems to work ok. It also has same problem if the selector dial is on floor/dashboard vents.
Suggestions?
Thanks...
Suggestions?
Thanks...
