jacksprat88
- January 22, 2014
- Ga.
- 2002 ford Ranger Edge 3.0
Hello, my namres richard and I have a problem. I have an '02 GFord Ranger Edge 3.0L standard cab pick up. Yesterday I jumped in the cab went to crank her up and NADA....dead all the way around. No interior lights,l dash lights, no buzzer....DEAD. I got my buddy to jump her off with his Ford truck and still NADA. Although it did show signs of life by all the lights coming on, dash, interior,etc...but as soon as I switched the key on to start the truck, BLACK out. Then no signs of life again. I ended up pushing it down driveway to garage where i put her on a slow charge for an hour. I opened door and the interior light comes on , insert key and all the dash lights come on then turn to start and NADA...all black again. I roll the key back to neutral position then turn her clockwise again and no signs of life whatsoever...so i leave her on the charger again and 2 hours laterb try and nadas but now the 'anti theft' signal is blinking rapidly and when i try to start her a weird noise can be heard from under the hood. even with key off and out of the ignition 'anti-theft' light blinks rapidly. So today i go get an Optima yellow top battery to replace the Interstate battery and nada. I know the alt. is good cause I just had a new High output alt in stalled. I checked the volts on batt and she reads 12.80. My key is an original Ford key that came with the truck. I have lost 1 key and had a replacement made at Ace Hardware for 60 bucks cause its got a sensor and it worked fine till i lost it. But so i still have this ford key thats been working fine...can someone help with some ideas on whats up, thanks
ps- I have checked all the fuses (drivers side and under the hood). I just checked all wiriung again ands had battery unplugged for an hour. when i hooked it up all lights were on and I went to crank it up and as soon as i flipped the ignition switch ....powers gone. I'm sure its the PATS system. Can I take the key I have now(original) and get a duplicate made(60 bucks@ ace hardware) and use it to start the truck?? I know that's a broad statement cause a number of things could be wrong withe the PATS system not just the key going bad.
